Page 1 of 13 12345611 ... LastLast
Results 1 to 15 of 187
    Default Radio Code app for Alfa Romeo
    I'm looking for a app for decoding Radio Code for Alfa Romeo Radios.
    I have found some Blaupunkt decode software but doeas not work with Alfa Romeo Radios.
    Does such software exist and is it somewhere to D/L?
    morocco/fbs
    explain what did you want to do
    code or disable canchek
    for code
    Available for most Blaupunkt Fiat,Peugeot,Alfa Romeo Car radio's with fixed code numbers
    Blaupunkt Fiat - Code 1111-6666
    Blaupunkt Peugeot (T1 Range) - Code 1111-6666
    Blaupunkt Alfa Romeo - Code 1111-6666
    For examp : Calculate code number for Alfa Romeo 937 CD HIGH
    BP part number:7 649 378 316 Serial number:BP9378B0034218
    Enter in calculator - 3780034218 CODE: xxxx
    For examp : Calculate code number for Fiat DucatoCC
    BP part number:7 649 373 316 Serial number:BP037323209271
    Enter in calculator - 3733209271 CODE: xxxx
  3. The Following 22 Users Say Thank You to jokersat For This Useful Post:
    armpower (11th May, 2018), canisha (20th January, 2022), cruzpablo (20th September, 2024), Decode Ghost (19th May, 2017), eleeinidis (8th October, 2018), gogoli (16th January, 2023), k70tomi (15th May, 2016), kido resuri (5th February, 2019), klesk1986 (2nd October, 2022), Kraftkanzler (2nd September, 2022), LPSERV (18th January, 2016), Magoforrest (16th August, 2021), marek527 (16th October, 2022), peppefender (10th July, 2021), piter1081 (17th October, 2019), Salkhi (28th June, 2023), sannyk (27th February, 2017), sep382 (29th January, 2019), sikib (1st September, 2016), soukehal (7th November, 2020), tecnada (21st May, 2016), TECNO3 (2nd May, 2018)
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by Prutsor View Post
    Don't you need to put a 0 for the serialnumber you put in the calculator. Thanks for the prog.
    Not if it's not in the serial number mate ......
    tunisia
    try to use nyo 4 it can help you
    Quote Originally Posted by jokersat View Post
    for code
    I too am looking to decode a BP0378 radio
    Alfa 156 HIGH CD - looking for the code if anyone can help me. - please
    SN - BP037834818467
    morocco/fbs
    your code is 6266
    i need help with my radio too.
    Alfa 156 Blaupunkt Radio
    Prod. Nr. Fiat: 156 034 208
    BP Nr. 7 640 376 316
    BP (side serial) BP037610765xxx
    Can someone give me the code?
    Thanks in advance.
  10. #9
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by rossi46 View Post
    Thanks in advance.
    Introduce yourself to the community mate ...then when you come back your code will be waiting....
  11. #10
    Ok, I know it looks like I'm just wanting to get some code for free.
    I'm buying a radio from someone and he doesn't have code. So I just wanted to get and test code before buying this radio.
    That's all I need from your community.
    If not, no problem, no hard feelings.
  12. #11
    Moderator
    PremierD's Avatar
    Jun 2009
    Ok mate if thats ALL you need from our comminity ..then there are no hard feelings ...Oh! and no code either ..Go elswhere for your FREE code..
  13. #12
    DK Veteran deffc0n's Avatar
    UK/POLAND
    Work Work very nice
  14. #13
    Hello.
    Works just had the opportunity to check out.
    Exactly as in the instructions.
  15. #14
    I need a code for an Alfa Radio s/n:-
    cl218v0009820
    Anyone able to help?
  16. #15
    uk
    Hi All,
    After disconnecting my battery, I know need a code for the radio.
    The serial number is as follows
    Bp037834853724A
    If any one can provide the code or where to download the calculator I would be most appreciated
