    Default Peugeot 308 1,4 Vti P1336, P1337, P1338, P1339, P1340
    Ahoj,
    I have a problem with Peugeot 1.4 VTI 70 kW year 2008 about 95000km.When the engine starts, it runs smoothly, after approx. 3 minutes the engine starts to tear, the fan starts to run until the engine stops. DTC P1336, P1337, P1338, P1339, P1340 Done:Cylinder head and valve repair, gufer Replacement of timing sets, spark plugs and ignition coils, camshaft speed sensors, phase valves, oil + filter, el.thermostat,The compression pressures are ok, the values from the temperature sensors are ok too,el. ignition coil line - ECU, GND, ok will be grateful for your advice.thank you very much
    Portugal
    Hello.
    Before it was repaired, the car already had this problem?
    These distributions on these engines have to be very timely, because otherwise they can start counting faults in the cylinders.
    Aug 2012
    BALTIC
    hi. chek timing chain, p1340 synchro fault and other all cylinder misfairing
    Thanks you, timing set accurately, now the error of the 1st cylinder P0301 appeared, after a while error 4th cylinder P1340 .....
    Apr 2021
    Hi, how you fix it ? becouse i have that same problem
    Portugal
    Measure the compression in the cylinders to see....
    Try changing the spark plugs from the 1st to the 2nd to see if the 1st malfunctions again.
    In case it malfunctions again, you may have a problem with the injectors that can also cause combustion failures.
    Another possibility is to have some software update through diagbox.
