Results 1 to 13 of 13
Thread: BMW E60 error
    r_parev's Avatar
    Bulgaria
    Default BMW E60 error
    Hi, please help with this error- A3B6 in combi instrument.
    "Message error ( data storage Condition Baset Service, 0x394), receiver instrument panel, transmitter CAS"
    The instrument cluster shows the km that are in the CAS, the km in the instrument cluster are displayed in 1 second while the car starts only.
    BMW E60,2005,530D
    Km in CAS "309424"
    Km in tacho "89900"
    tacho shows -309424
    i change km, but
    Km in Cas "0"
    km in tacho "209400"
    tacho shows -0
    May 2016
    can post bin files ?
    br
    r_parev's Avatar
    Bulgaria
    Quote Originally Posted by SKYTON View Post
    br
    Here are all the files......
    brend's Avatar
    Oct 2015
    Same where
    km set no good.
    What km need?how much you need?
    r_parev's Avatar
    Bulgaria
    209400km please.
    brend's Avatar
    Oct 2015
    Same where
    Cas good.only dash no good.
    Red dot up to??
    brend's Avatar
    Oct 2015
    Same where
    If red dot up.I think dash vin not same , what in cas.Its mean dash dump in another car.
    Put this ........
  8. The Following User Says Thank You to brend For This Useful Post:
    r_parev (29th March, 2018)
    r_parev's Avatar
    Bulgaria
    I did not pay attention to a red dot.
    Tomorrow I will try with new dump and report.
    Thanks.
  10. #9
    r_parev's Avatar
    Bulgaria
    Vin in CAS.........
  11. #10
    brend's Avatar
    Oct 2015
    Same where
    I know .
    In dash CX14XXX
  12. The Following User Says Thank You to brend For This Useful Post:
  13. #11
    r_parev's Avatar
    Bulgaria
    Thank you, you are very right, I did not pay attention to this detail
    ps
    Now I remember, the owner said , the cluster and mileage had changed a long time ago.
  14. #12
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by r_parev View Post
    BMW E60,2005,530D
    Km in CAS "309424"
    Km in tacho "89900"
    tacho shows -309424
    i change km, but
    Km in Cas "0"
    tacho shows -0
    i had the same problem before...same symptom with red dot....
    problem was fixed by coding dash again to the car...if you have clone fvdi it can do the job... after coding you need to remove plug of dash then reput again... then your dash will work ok and the real mileage will appear and the red dot will dissapear....
    step is so simple ... if you need more info let me know...good luck
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  15. The Following User Says Thank You to eliaselias For This Useful Post:
    r_parev (30th March, 2018)
  16. #13
    r_parev's Avatar
    Bulgaria
    Problem is resolved, thanks to "brend" - inserted correct VIN into a dash dump.
    Thanks to all for help.
  17. The Following User Says Thank You to r_parev For This Useful Post:
    brend (30th March, 2018)
