Results 1 to 14 of 14
    Dec 2017
    Default Nissan Juke Pin code
    I am working on a Nissan Juke that lost all the keys. I need to generate pin code to be able to learn new keys. The problem is that the code in the glove box is only 11 characters long. How can i solve this problem?
    Thank you!
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    Find BCM in driver side and put a pic from label to get pin code
    Cheers
    Press "THANKS" button. just one click, CHEERS
    Dec 2017
    This is the label from BCM.
    electrones's Avatar
    Feb 2012
    Around C.V
    TRy this friend
    old : 2693
    new:9917
    Cheers
    Oct 2017
    hi, Im curious. HOw do you know its the date code and encryted code. thanks
    calin_bm's Avatar
    near civilization
    thank you, I have already tried this codes, but it need 12 bytes code lenght...
    calin_bm's Avatar
    near civilization
    this is the content of the Bcm eep.
    Mr_Fix's Avatar
    Try - xxxxxxxxxxxx
  9. The Following 2 Users Say Thank You to Mr_Fix For This Useful Post:
    calin_bm (31st March, 2018), kollariks (31st March, 2018)
  10. #9
    Dec 2017
    Mr_Fix that is the code that the dealer provided for the car. But it does not work on this car. After that they said that they did not know what to do next. Also the sticker in the glove box is really strange, it has only 11 characters.
  11. #10
    Feb 2014
    Got hit by the same model car with AKL that went through other locksmiths too. It won't accept any pin code. It has the same BCM model like in the third post.
    It seems it is some mix between Renault and Nissan that is different than the rest of the Jukes. It has Renault diesel engine with SID305 ECU.
    It only reacts to 12 symbol PIN programming procedures, but it does not accept the one from the glovebox (this one has 12 symbols on the sticker at least).
    Dealer supplied code also didn't work at another workshop(I don't know what they supplied). I see there is an emulator procedure for this ECU for Renault but I don't think it will work on this Nissan model.
    EEPROM also didn't work, only difference is it starts to blink an additional yellow key symbol on the dash and then nothing. And after EEPROM programming the lock/unlock button on the door stops working until all keys are erased by diagnostic procedure.
    Did any of you find solution to this? I see many cases for the same combination of BCM and ECU on Juke and no one has posted a solution or even a hint. Even official dealer can't help on this car when it's AKL. I guess situation is the same for second key programming. So what do people do when they lose all their keys - throw the car to the bin?
  12. The Following 3 Users Say Thank You to autoTkey For This Useful Post:
    Arcadius82 (15th December, 2022), fred77 (29th March, 2021), kronk92 (15th October, 2024)
  13. #11
    Jul 2013
    hey I do also look for immo code, my car is Nissan Juke 2012 1.6 DID-T Tekna 4x4- all keys lost.
  14. #12
    Dec 2017
    NEW 2131 OLD 1050
  15. #13
    Feb 2023
    Hi, how did it end ? I am having the same situation.
  16. #14
    richard27's Avatar
    Aug 2011
    Quote Originally Posted by calin_bm View Post
    bu Bcm eep'nin içeriğidir.
    you pin code: ADE97EF94E35
    ​information sharing
