Results 1 to 15 of 16
    Oct 2016
    Default Renault CAN Clip 176 [2018]
    Enjoy!
    if I helped you, please press THANKS+REP.
  2. The Following 18 Users Say Thank You to AndreiBBF For This Useful Post:
    Brolk (2nd April, 2018), dupisa (7th June, 2018), eliet2000 (2nd April, 2018), ferdifil (14th March, 2019), GianniNOS (4th April, 2018), houdiag (5th June, 2018), kamelkamel (16th June, 2019), korfi (25th May, 2018), marianek (20th June, 2021), mexanico1971 (11th May, 2018), ovitanov (11th May, 2018), racin-snake (15th April, 2018), saibox (19th June, 2019), SANTI-MECCANICA (8th April, 2018), sep382 (4th January, 2020)
  3. #2
    Dec 2015
    Italy
    it work on win7 64bit?
    Member SANTI-MECCANICA's Avatar
    May 2009
    Hello, he will not let me install. Can you tell me the problem?
    Thank you
    norfolk uk
    You need to instal other software first, clip platform, you can find on this site
    May 2009
    Can you tell me how I do it? I do not find anything of the subject.
    Can you give me a link for PM
    I'm installing it in XP
    Thanks in advance
    Oct 2015
    Quote Originally Posted by SANTI-MECCANICA View Post
    Thanks in advance
    XP is not supported
    Please use other OS
    May 2009
    Hello again I tried on Windows 7 64bit and it does not work, can you help me?
    Nov 2015
    GENERAL INFORMATION Clip :
    -Starting with version CLIP 173, Windows XP is no longer compatible with CLIP.
    ***Warning :
    -Maintenance of the Tecra A11 and CF19 MK2 ceased in January 2017 and they can no longer be registered.
    -Since January 2016 the DELL E5500 units have no longer been serviced and cannot therefore be registered any longer.
    -Since August 2015 the PANASONIC CF19 MK1 units have no longer been serviced and cannot therefore be registered any longer.
    -Maintenance of the PANASONIC CF18s ceased in May 2014 and they can no longer be registered.
  10. The Following User Says Thank You to Frankcar For This Useful Post:
    SANTI-MECCANICA (15th April, 2018)
  11. #9
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Hi, SANTI-MECCANICA
    I have to add Clip does not work on 64 bits systems because of the probe drivers.
    You have to do changes in register prior to install Clip, that's why you see a warning message " esta plataforma etc"
    Open Google and look for this: Renault Clip Tool_2.6
    Every thing you need to install is included there in this marvelous software!
    Por favor, piensa en hacer un clic en los "thanks" y agregarnos tambien el boton "reputation" a todos los que te hemos ayudado, compadre.
    Saludos,
  12. The Following 2 Users Say Thank You to Louislesinge For This Useful Post:
    Dr Alex (28th October, 2019), SANTI-MECCANICA (15th April, 2018)
  13. #10
    May 2009
    Thanks again does it work in windows 7 32bit vmware?
    You will tell me
  14. #11
    Jun 2017
    French Jungle
    Yes, should work. Once I tryed to install it on vmware but allways fighting with the USB drivers, I prefer a clean installation on true system. I actually did my computer this way: first i did install Win XP (with older CLIP like 65) and then Win 7 (with latest CLIP) that's a good way because Win 7 sees there is another older system and create a boot loader to make your choice.
    Did you reach to download Renault Clip Tool_2.6?
    Firt you have to use "registry patch" to make the software CLIP accept to begin the installation. When insatallation done you can use the key generator to validate it.
    Saludos,
  15. #12
    May 2009
    Okay. If you downloaded renault tool 2.6.
    Now I must install it in Windows 7 32bit.
    Thanks for the help.
  16. #13
    May 2018
    where i can find clip platform?
  17. #14
    Oct 2016
    canclip with gold pcb is the best
    You can find it on ebay, aliexpress, etc
  18. #15
    Oct 2016
    Canclip 176 works only with win7, win 10, 32 bit.
    Tomorrow i will post v177 software.
