hi masters
i have problem with passat b6 abs trw440
3c0614109p
fault code 00283 wheel speed sensor left open or short to plus
i check all wiring ok sensor ok
then i remove abs and found problem infineon orion c2 burned out for this sensor
i have other abs different number
3c0614095s
original abs coding
0002322
other 0013605
how to coding second hand module?
this is a pic burned chip....
