Results 1 to 4 of 4
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default Please help to remove DPF and dtc from Seat Ibiza 1.2tdi DCM3.7
    Is there anyone they can help me with this ecu?
    DPF is cutted and car give now EML check engine light.
    I read with diagnostic and i receive P2002
    ADS don't work on this ecu..
    SO need manual solution DPF off and remove this DTC
    Very thanks!
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    netherlands
    Quote Originally Posted by sdtsedat View Post
    Very thanks!
    Hi mate How Did you read? Which tool
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Quote Originally Posted by pluto2013 View Post
    Kess v2 geniune
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Sedat Garip
    Belgium
    With Kind Regards,
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Solved
    Case closed
    Sedat Garip
    Belgium
    With Kind Regards,
