Results 1 to 3 of 3
    DK Veteran deluss's Avatar
    Jun 2011
    Default IAW 4AF.SS HW407 P0351
    Hello, i have problem with Fiat Panda IAW 4AF.SS i have still P0351. I change coil, spark and still have problem. Someone know how to repair ?
    tinchocbr's Avatar
    In my house
    Check ic coil with tester if is damaged change.
    I repair 4af than the tester its ok, but in the car not working, i changed ( i not remember if was vb325 or 525) and work wells (i looking with osciloscope input signal from mcu before change IC)
    Sorry for my bad english.
    Dec 2013
    Holland
    Your ecu is broke most of the times there are a lot of panda they have the same problem some bad connetions in the pcb are broke
    http://www.actronics.eu/ecu-magneti-marelli/ here you can see the problems with this ecu
