Results 1 to 9 of 9
    super jumbe's Avatar
    Livingstone
    Default Toyota corolla verso 2004 start/stop remote programming help.
    I've got in garage Toyota Verso 2004 that works with push button start rather than a traditional key.
    The car starts fine but the key fob won't lock or unlock the car, I've changed the batteries and still fob not working, I can not find instruction on line, can some one give me instruction how to program remote?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Did one today. From first time
    Take out key
    Open drivers door leave open
    Put key in out 2 times
    Close open driver door 2 times
    Put key in slot take it out
    Put key in slot
    Close driver door
    Push start button 2 times ignition come on
    Turn of ignition
    Remove key from slot(door lock should cycle )
    Push both buttons on key same time hold few seconds release push close button.
    Done.
  3. The Following 5 Users Say Thank You to drugowaz For This Useful Post:
    lalaina74 (18th May, 2019), musti418 (25th June, 2018), nhobe79 (27th November, 2018), skizo89 (20th December, 2022), super jumbe (16th April, 2018)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    It was spare key.
    If yout key was added before. You can trty not push lock button in end. Only both buttons same timeand hold. Than try start car. Remove key and test remote
  5. The Following User Says Thank You to drugowaz For This Useful Post:
  6. #4
    Livingstone
    Mate this is not the tradition key, when you say take key in/out 2 times still do not understand how, this is the remote below.
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Vetso key is diferent.
    Your key is smart type
    Verso is regular remote slot key
  8. #6
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This is verso key
    http://carkeyservice.ie/shop/car-key...corolla-verso/
    Car have slot for key or only start button. If start button its smart key system.
    use diag equipment to reprogram
  9. #7
    Livingstone
    I did mention on first page as Toyota corolla verso 2004 start/stop remote programming.
    Did this way today.
    (1) Take out key
    (2) Open drivers door leave open
    (3) Put key in slot in and out 2 times
    (4) Close open driver door 2 times
    (5) Put key in slot take it out
    (6) Close open driver door 2 times
    (7) Put key in slot
    (8) Close driver door
    (9) Push start button 2 times ignition come on
    (10) Turn of ignition
    (11) Remove key from slot(door lock should cycle
    (12) Push both buttons on key same time hold few seconds release push close button.
    Done.
  10. The Following 2 Users Say Thank You to super jumbe For This Useful Post:
    asto (1st March, 2021), lion0304 (17th April, 2018)
  11. #8
    Oct 2017
    i think Receiver is not good.
    this is smart key and it programmed.
    see does it open lock when you touch driver or passenger side?
  12. #9
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Quote Originally Posted by super jumbe View Post
    Did this way today.
    (1) Take out key
    (7) Put key in slot
    Done.
    Are you joking? I alrrady told you procedure and you writing here same.
    all verso models not have regular key all have start stop keys.
    One my photo is remote slot key.
    your photo is smart key.
    I dont get it do you have slot near button or not. As previous you tell you dont understand about put in out key.
