Results 1 to 12 of 12
    Slem's Avatar
    Oct 2015
    Default Toyota Crown 2004 smart key all key lost ..
    Hi mates ..
    I need to know how to program the old Toyota crown made in japan 2004 smart card system all SK lost .. this system is contain separate transponder 4D67 and smart card all embeded in the same smart key , (Intelligent key) + Transponder type, the smart ECU have S2943.
    I tried Mr Brayn solution for Prius NHW20 Some Lexus but its its not work . I have only used smart key ..
    Slem's Avatar
    Oct 2015
    Dears, Need your help
    Slem's Avatar
    Oct 2015
    Any one can help here ?
    klaudio's Avatar
    Jul 2016
    never worked on one, i can only give suggestions, try reading eeprom as 93c66, 93c56, 93c86 to see if you get a dump that will be recognize by a programmer, I did look up the eeprom number and can't find much information on it. If you have tango+ give it a try.
    ​Some people just want glory instead of acknowledgment.
    Thanks and reputation is earned, not ask for.
    Have a nice day.
  5. The Following User Says Thank You to klaudio For This Useful Post:
    Slem (23rd April, 2018)
    Jun 2016
    I read the Brayn solution.
    It work 100%.
    Maybe your procedure is wrong.
    You can use a used smartkey.
    Please write the detailed instructions you did.
  7. The Following User Says Thank You to automecha For This Useful Post:
  8. #6
    Slem's Avatar
    Oct 2015
    I red the S2943 eeprom in the smart box as 93c76 and 93c86 and wote the Brayn resetted bin file to it and went to the car and starting register a used smart key and used the Toyota techstream V 12.10, SKP900, x100pad 2, x100 pad plus and Gscan .. its failed to register the smart key .. and i noticed that when the Brayn solution witten to the smart box the security LED will blinking fast but when the ORI file returned to the smart box the security led is came back off.
    i red the S2943 as 93c86 and attached it to Tango but not accepted because the invalid file size ..
    Note .. the used smart key is all black colour not the gray one .. any one can give me hand in that ? a virgin file for the attached 93C76 will solve the problem ..
    Slem
  9. #7
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by Slem View Post
    Slem
    I think i might have your solution, I imagine this is the one you have to put the fob inside a slot. if it is, read ecu 93c56 and emulate or write new 4c transponder, put new transponder inside fob, that should start vehicle, once you do that you should be able to program remote manually.
    Have a nice day.
  10. The Following User Says Thank You to klaudio For This Useful Post:
    Slem (24th April, 2018)
  11. #8
    Jun 2016
    My solution
    1 Put the master key inside slot.(Master key is black color.)
    2 Reset the transponder ECU.(I use a T-300. If you have it, You choose TOYOTA - IMMO - TYPE2.
    3 After reset,You have to put off the smart key from the slot.(security lamp on)
    4 After security lamp on,Put rhe smart key insaide slot again and Push start switch on - off five times.(security lamp blinks)
    5 Write the virgin file to the smart Ecu.(S2943-93C76)
    6 Put the smart key the inside slot.
    7 Register smart function using Tchtream.
    Done
    regards
  12. The Following 3 Users Say Thank You to automecha For This Useful Post:
    Greyh666 (17th June, 2023), keiya (9th February, 2021), Slem (24th April, 2018)
  13. #9
    Slem's Avatar
    Oct 2015
    Klaudio .. The car have 4d67 chip not 4C, and there is no manual programming for the smart function. This car is Japan plant manufacturer not USA ..
    Automecha .. thank you i will try your solution and report here ..
    Best wishes
    Slem
  14. #10
    klaudio's Avatar
    Jul 2016
    Best wishes
    Slem
    Yes, you're right, found this thread that might solve your problem. http://www.digital-kaos.co.uk/forums...y-all-key-lost
    Have a nice day.
  15. #11
    Aug 2018
    Pathein,Ayeyarwady,MYANMAR
    Please reply
    Slem
  16. #12
    Jul 2020
    My 2004 toyota crown has the same problem. How do i use Mr. bryan solution???
