    Jan 2013
    Default BMW EWS 4 Clone?
    Hi Guys need some advice please I am helping a friend out who is very far away. This is the story he has, had a customers vehicle in his workshop BMW Z4. He lost customers keys seeked the assistance of Locksmith locksmith made key car cranked few times but no start then no crank at all. Then Customer brought spare key and no crank. Then you could not reach the EWS with Diagnostic. Locksmith refered client elsewhere who then gave customer big quote to repair ecu. ECU and ews ended up by me.
    What i See
    1.) Someone worked on EWS4 and attempted to BDM Read ECU all the BDM (ECU MSV70) points had solder on even ones that are not used durring BDM read.
    2.) Ews4 smd cap had one side contacts burnt off, someone had worked on box using too much heat (bottom solder on board melted and started to drip.)
    3.) I Cant read EWS with xprog or R270.
    Locksmith supplied me with original EWS dumps
    Im Considering the following
    1.)I have donor EWS i can change vin and isn and code chip
    2.)I write back their dump to donor box (I have heard this doesnt always work) Then their spare key will still work
    3.) option 2 and 3rd option where i change isn vin in EWS3 box and code chip incase option 2 dont work.
    Any thoughts?
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
    Jan 2013
    Default Dumps
    Here are the Dumps, would be cool if i could write his original dump to new ews and he could use old key i have read that it doesnt work.
    kiszka's Avatar
    Reality of life :
    4:Everyone lies
  5. The Following User Says Thank You to kiszka For This Useful Post:
    geeroam (19th April, 2018)
    Feb 2018
    Glasgow area
    I've overwritten EWS 3 eeproms on to donor modules often with no problem.
    I'd expect Z4 to be EWS 3 too.
  7. The Following User Says Thank You to PixelsFixed For This Useful Post:
    geeroam (23rd April, 2018)
  8. #6
    Jan 2013
    Its EWS4, I have read that some guys wrote old data from ews4 to new ews4 and didnt work, I have also done many ews3 with old data. I just wrote changed the isn and vin on new ews and made transponder hope it works.
