Results 1 to 8 of 8
    Jul 2016
    Default help pls Add blue or (def) counter reset range rover sport 2016
    hello friends
    pls i have a Range Rover sport 2016 model diesel engine it show me that remaining distance is 35 km before the engine will turn off as i have to add the add blue and i fill the add blue bottle and still showing the same distance and cant reset it and i am affraid that the engine will not start if the owner will drive his car
    help pls
    Jul 2016
    any help pls ??
    mihaiservice's Avatar
    http://www.quick-tuning.com
    You have to use IDS JLR or you can try to turn ignition off/on 30 times for "manual reset" after adblue tank are refilled if there not are any "bug" in software !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  4. The Following User Says Thank You to mihaiservice For This Useful Post:
    cyril (23rd April, 2018)
    Jul 2016
    thanks for ur reply i will try manual reset and reply
    Jul 2016
    and pls just a question as i refill the add blue is right if the counter will arrive to 0 it will not start again?
    Yes,will not start anymore !
    Full WinOLS user
    Jul 2016
    it arrive to 30 km and i drove ther for 100 km and its not counting anymore any idea ?
    check driver/owner manual if are any procedure to reset adblue after refill !
    Full WinOLS user
