Results 1 to 15 of 24
    mastaflex's Avatar
    Jan 2009
    FR47310
    Default IMMO OFF on Bosch MP9.0 .
    hello :
    I want to make an IMMO oFF on Bosch MP9 ECU. i have Immocleaner 2.0 but the ECU described on the soft With same reference is not the same that i have. please can anyone help me by giving me the detailed steps.
    thanks to all...
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    This ECU is year,...car,...Probably solution is here.Post it.
    mastaflex's Avatar
    Jan 2009
    FR47310
    ECU for polo 6N1 1.4 with engine AEX
    here is infos for the ECU:
    manufacturing date 12/1995
    BOSCH MP9 reference 0 261 204 054/055
    VAG reference is 6K0 906 027 A
    with TMS 1J5T eprom
    and bosch 56BLB58258 (SOIC 8)
    what i have to do to make an immo off on this ECU.
    note that i have immocleaner 2.0 but the ECU described with the same reference on the soft
    doesn't have same mainboard.
    for more informations you can see the pictures attached.
    thank you
    mastaflex's Avatar
    Jan 2009
    FR47310
    I forget to tell you that my car is a polo and because of an ECU crash i taked used one with its engine from a seat ibiza 1.4.
    so all the infos that i gave you are for new ECU
    Listen,your Polo have immo box(black box under inst.cluster or steering wheel)Take it immo box,reprogramed hc05 into box(manual for this find it here)and must next;Engine-adaptation-channel 000-read-save-done,go back and thats it.Ignition off-connect your reprogramed immo box without antena jack-ignition on-start engine and must be OK.I tested many modules 1.4 ccm(and others ecu) and all works.
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Quote Originally Posted by mastaflex View Post
    hello :
    I want to make an im*o oFF on Bosch MP9 ECU. i have im*ocleaner 2.0 but the ECU described on the soft With same reference is not the same that i have. please can anyone help me by giving me the detailed steps.
    thanks to all...
    its polo 6N your immo is in 87C510
    if you have UV eraser or virgin one pump this dump into ....
    mastaflex's Avatar
    Jan 2009
    FR47310
    i will test and tell you
    mastaflex's Avatar
    Jan 2009
    FR47310
    Quote Originally Posted by MOBILTRONIC View Post
    Listen,your Polo have im*o box(black box under inst.cluster or steering wheel)Take it im*o box,reprogramed hc05 into box(manual for this find it here)
    please where can I find manual for this here?
    Default im*o off hc05
    You follow earlier procedure of me and with this dump reprogramed hc05.Engine must be started.Use Motorola cracker 6.0 or Upa serial or UPA usb.If not to read hc05 with Motorola cracker,serial upa or UPA usb use ETL programer.If use ETL must be bin dump convert to etl extended file or manual on address exchange dump.Its very easy.Open my dump in hex editor of cracker and compare this files with orig.files and see you differences.That help you if need reprogramed hc05 with ETL programer.Good luck!
    Default immo off hc05
    Sorry,my comp....Here is dump with im*o off for hc05.Good luck!
  11. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    digikeys (21st January, 2021)
  12. #11
    dimet's Avatar
    MKD
    This not work i try today
  13. #12
    damih's Avatar
    france
  14. #13
    Apr 2011
    Record 24c02 with serial file, and be totally immo off!
  15. The Following 41 Users Say Thank You to INJECTMDS For This Useful Post:
    aimen96 (13th July, 2022), ascotauto (4th September, 2017), auto-diag (13th July, 2022), azoki981 (18th May, 2021), bresto100 (26th April, 2024), ceko1993 (19th February, 2023), cheaper (5th January, 2024), danielif (20th June, 2022), dj_piex (4th September, 2024), EMCE159 (26th February, 2015), fadi sharaf (15th October, 2018), Ginocar (24th September, 2024), gthomas2 (28th December, 2020), hartklep (6th June, 2018), Hayssam1 (5th May, 2021), Hazzard (7th October, 2017), igori (4th December, 2020), illestibor (26th February, 2018), Jacob6969 (3rd August, 2022), Kriszy (13th January, 2020), kroy0402 (15th December, 2022), mkii (25th July, 2022), Nols Theron (7th June, 2022), Osvaldo (16th May, 2024), Paranoiak (30th October, 2017), PauloFerreira (12th October, 2017), Pezhoo (18th January, 2025), plamen 63 (20th April, 2024), reglissebudy (4th October, 2017), Roche (10th November, 2018), rumensivanov (13th June, 2020), sevid (6th June, 2018), sharpshooter86 (10th November, 2022), simin123 (24th September, 2022), snakebyte (24th May, 2017), Stelaras26 (9th November, 2019), taxi300 (4th October, 2017), tune7 (17th February, 2020), vwdamian77 (5th June, 2018), Xlam (22nd September, 2019), xseva (17th May, 2023)
  16. #14
    South Africa
    Great job Injectmds your dump works , thanks a lot
    regards
  17. The Following User Says Thank You to ecufix For This Useful Post:
    Stelaras26 (24th November, 2020)
  18. #15
    Oct 2017
    I'm trying to immo off this ECU. Can I read and write 24C02 on board without desoldering? Using CARPROG.
