Results 1 to 9 of 9
    Jan 2018
    Default Delphi DS 150e + Wow wurth 5.00.12
    Hello Guys,
    I would like to use my Delphi 150e interface with the Wow wurth 5.0012 software.
    But I do not know the procedure to follow and what firmware to use.
    Thanks in advance,
    Dec 2014
    PL
    Quote Originally Posted by SR71 View Post
    Hello Guys,
    Thanks in advance,
    You must paste the firmware from wow wurth 5.00.12 to Del... . Then both software will work correctly with the tester without the need for an update.
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    SR71 (5th May, 2018)
    Jan 2018
    I finally found the solution, if it happens to another forum member.
    I used the firmware 1622 for wow and delphi.
    And in Wow you have to choose Snooper + BT even if your VCI doesn't have bluetooth.
    Best regads,
    Mar 2017
    hi friend what is the best firmware and software for wow and delphi thank you
    Feb 2016
    hi ive got wow wurth 5.8 but when i try open the wow exe file it doesnt open or do anything can anybody help please thanks
    Mar 2017
    friend what version of delphi you have to get this firmware update 1622
    Newbie issaqigu's Avatar
    May 2018
    france
    good evening
    have you installed and activated wow 5.00.08 or are you trying to install it?
    have you installed java and done your updates before??
    otherwise wow 5.00.08 or 5.00.12 work well with delphi 2015.1 rev3 with firmware 1612or 1622
    Sincerely
    wow 5.00.12 are you sur ?
  10. #9
    May 2018
    france
    Quote Originally Posted by electrohicham View Post
    Hello
    wow version 5.00.12 is of course an unofficial version that is do-it-yourself based on 5.00.08
