Results 1 to 14 of 14
    Jan 2018
    Default How to read EDC15C2 3 plugs Peugeot 307 HDI - Boot mode Galetto V54
    Hi guys
    I try to read the dump of a flash ECU EDC15C2 with Galletto V54 in pinout and boot mode but I can't. Should I connect the Galletto ground (black wire) (with or without the resistor 5Kohms) to flash PIN 24 or Galletto's gray wire (boot) for the boot mode. I want to make an immo off on the Flash 29F400BT.
    I need your help !
    Thanks in advance,
  2. The Following 2 Users Say Thank You to SR71 For This Useful Post:
    ahcen elctro (22nd June, 2019), psabad (31st August, 2022)
  3. #2
    Jan 2018
    PL
    Desolder the flash and read it in the programmer
  4. The Following 2 Users Say Thank You to rch11 For This Useful Post:
    ahcen elctro (22nd June, 2019), SR71 (7th May, 2018)
  5. #3
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    here is pinout my friend!
  6. The Following 4 Users Say Thank You to Stelaras26 For This Useful Post:
    ahcen elctro (22nd June, 2019), HAMIZA (19th September, 2019), martinracing (8th May, 2018), SR71 (7th May, 2018)
  7. #4
    Jan 2018
    With a programmer it will be easy but I do not have one.
    I only have Galletto to read the flash.
    Thanks, but I already know the pinout but it's the procedure to follow for reading (boot mode) with Galletto V54 that I looking for.
  8. #5
    Jan 2018
    I have to connect the ground to the PIN 24, or put a resistance of 5 kohms with the ground, or use the gray wire of the galletto adapter.
  9. #6
    Jan 2018
    Or is it possible to off this in the eeprom 5P08 ?
  10. #7
    Jan 2018
    I always get this error message when i try the boot mode with Galletto.
  11. #8
    rafal's Avatar
    UK - PL
    1-connect ground to boot pin
    2- switch power on to ecu
    3- disconnect boot pin
    4- read ecu
    need help
    now my goal is to buy xp-005
    who will help?
  12. The Following 2 Users Say Thank You to rafal For This Useful Post:
    ahcen elctro (22nd June, 2019), SR71 (8th May, 2018)
  13. #9
    Jan 2018
    Hi Rafal,
    That's what I did but at the moment of reading I get the error message: Boot mode inactive. I was desperate so I tried to desolder the eeprom 5P08C3 to see if it started. But no, it still doesn't start. There is no other solution with the Eeprom to off the immo ?
  14. #10
    tek2dk's Avatar
    Oct 2012
    under the sea
    You must remove feeding only form ECU. Do not remove form G54.
  15. The Following User Says Thank You to tek2dk For This Useful Post:
  16. #11
    Jul 2013
    Quote Originally Posted by SR71 View Post
    Hi Rafal,
    read eeprom and post dump
  17. The Following User Says Thank You to petronijul For This Useful Post:
  18. #12
    Jan 2018
    Herewith the dump file of the Eeprom 5P08C3
    For more information, the Bsi is unmatched with the ECU and I do not have a Lexia to do it. that's why I decided to do an immo off.
    I just want it to start even in limp mode.
    Thanks in advance Guys,
  19. #13
    Jul 2013
    try this file with new eeprom 95080
    good luck
  20. The Following User Says Thank You to petronijul For This Useful Post:
  21. #14
    Jan 2018
    I have to use a new Eeprom or could I use another Eeprom from another ECU (EDC15C2) ?
    it will not work if I use his own Eeprom ?
