Results 1 to 14 of 14
    Mar 2017
    Bulgaria
    Default Peugeot 307 EDC15C2 key programming and pin code?
    is it possible to program another car key with ID46 chip for peugeot 307 2.0 HDI EDC15C2 with DIAGBOX?
    I have the lexia evolution cable with Diagbox 7.56 installed. I guess I need the pin code to learn 2 keys ( because I have only one)
    Can this code be extracted from ECU dump file read by MPPS?
    brend's Avatar
    Oct 2015
    Same where
    Ecu/Bsi eeprom need for this.
    Sended dump its flash and this not have pin location.
    Mar 2017
    Bulgaria
    I do not understand - don't know what is ecu/BSI eeprom .... is it something to download with some tool and use OBD port or must dissassemble whole car comp "on the bench" ?
    Sorry for stupid questions ...
    brend's Avatar
    Oct 2015
    Same where
    For you safe job instruction for this!
    No reed eep by obd2. open ecu/bsi desolder eeprom,put this in programmer and read this.
    Quote Originally Posted by Teodor1 View Post
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
    Mar 2017
    Bulgaria
    I am reading something about pin from VIN ... is it possible?
    rafal's Avatar
    UK - PL
    will be better to give car for somebody who know what to do
    need help
    now my goal is to buy xp-005
    who will help?
    Mar 2017
    Bulgaria
    For sure ... agree with that... but the price is not reasonable for 1 key duplication ...
    2 money saving choices i have:
    1. Just remove the immo from ECU file - i already have modified immo off mine file
    2. If i learn somehow my security pin code i can use my cable and diagbox to learn 2 new keys
    Mar 2017
    Bulgaria
    Anyone want to help pin by VIN?
    rafal's Avatar
    UK - PL
    read again post #5
    need help
    who will help?
    Mar 2017
    Bulgaria
    Thank you for the reply, I just see so much post about pin from vin ... but I do not know is it suitable for my car - Peugeot 307. In my post No 8 I mentioned that I have diagbox with cable - if I knew my pin code I can learn 2 keys by myself. Obviously I can't desolder the chip and read the eeprom - I do not have tool for that (programmer) and just for duplicate a key I do not want to buy that tool.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    for PIN by VIN you´ll have to contact PSA Dealer...
    when you want from us the PIN from your car... you´ll have to open BSI or ECU... take out of the car... and still open it... locate eeprom (in most cases) and read it with an tool like xprog, orange5, and so on.... save dump and post it here... from the dump it will be possible to find out your PIN...
    Over OBD you´ll have to to work with FVDI/AVDI and so on... to get PIN... but it´s also high risk... when you try it in combination with JC BSI...
  13. The Following User Says Thank You to figani For This Useful Post:
    Teodor1 (17th May, 2018)
  14. #13
    rob h's Avatar
    May 2011
    Post your immo ecu file.
    This is the eeprom content, not the mmps flash.
    We can give you the pin from that.
    Pin by vin, dealer will do this. Not sure if it is free.
    And there have been some other providers, but they stopped this service as far is i know.
  15. The Following User Says Thank You to rob h For This Useful Post:
  16. #14
    Mar 2017
    Bulgaria
    Thank you all for the replies, I understand the case especially after the last two comments.
