Results 1 to 15 of 27
    Mar 2017
    Johannesburg south Africa
    Default polo 6r cluster dead
    hi. i was doing a vw polo 6r jc 95320 with fvdi and the cluster just went dead and car can not start. any help please
    When you use the
    THANKS and REP Buttons
    it gives energy to help more
    Appreciation is the key
    Nicolas9's Avatar
    Feb 2017
    Aruba
    try reset battery for few minutes?
  3. The Following User Says Thank You to Nicolas9 For This Useful Post:
    Dejfat (23rd May, 2018)
    Mar 2017
    i did for over 30min
    When you use the
    Nicolas9's Avatar
    Feb 2017
    Aruba
    did you exit service mode?
  6. The Following User Says Thank You to Nicolas9 For This Useful Post:
    Mar 2017
    i did not use service mode
    Quote Originally Posted by Nicolas9 View Post
    When you use the
  8. #6
    PierreTheron's Avatar
    Centurion,South Africa
    dID YOU READ EEPROM AND SAVE IT ???
    hERE vIVO 2011 DASH file 2011
    10b TO 10C CONVERT DEC TO HEX AND YOU HAVE PIN
  9. The Following User Says Thank You to PierreTheron For This Useful Post:
  10. #7
    Mar 2017
    i did not read before re calibration. i read the eeprom now and it is corrupt. i tried another dump from dk dash came on but no immo
    When you use the
  11. #8
    What year model your car m8 ?
    What number ecu in the vehicle ??
    Get pin from ecu
    Take another dash file
    Reset file with pin from dashfile and then code pin from ecu to dash file and job done ..
    Always make backup off any files where possible ....
  12. The Following User Says Thank You to PierreTheron For This Useful Post:
    sagie1zn (25th May, 2018)
  13. #9
    Mar 2017
    the car is 2014
    When you use the
  14. #10
    Mar 2017
    here dump file
    When you use the
  15. #11
    Can please put file from other dash on dk here so we can get pin ???
  16. The Following User Says Thank You to PierreTheron For This Useful Post:
  17. #12
    Mar 2017
    file from dk to compare
    When you use the
  18. #13
    Sep 2015
    Do you still have communication with dash?
    If yes, then:
    1. Try to read the IMMO data. Maybe it is not corrupted.
    2. Try to redo the procedure.
    If no - find someone who can extract the IMMO data from engine ECU and then prepare new (second hand) instrument cluster.
  19. The Following User Says Thank You to sendreq For This Useful Post:
    Dejfat (24th May, 2018)
  20. #14
    Sep 2015
    Quote Originally Posted by PierreTheron View Post
    Get pin from ecu
    This is not IMMO3 anymore, it will not work like that.
  21. #15
    May 2018
    Russia
    do you have anything to put the keys? if Yes, then read motor and the panel, out with the file, do sync, and the keys itself you will guess, with the ABS coding was not flown?
