Results 1 to 10 of 10
    Oct 2010
    Default Citroen c3 eco mode
    Good evening, one Citroen c3 1.1 gasoline came to my garage because the car don’t start, only turns about 2 seconds and stop.
    I can’t diagnose any unit except abs, car shows eco mode in display and I try to reset bsi using the methods are in google without success.
    There’s any way to reset bsi in trough dump ?
    Joze
    Enviado desde mi iPhone utilizando Tapatalk
    Oct 2010
    Quote Originally Posted by joze View Post
    Joze
    I forgot to tell you that the car was in other garage where they change the timing belt but I think the problem is not there because I can’t read units
    cheero's Avatar
    Czech Republic
    when no start car = eco mode active
    when start car = eco mode inactive
    light led on tacho from ecu ? have ecu ok power +12V and gnd ?
    ++++ GOOD WORK ? + ++++
    FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
    Oct 2010
    When I connect the battery the odometer and displays turn on but when I turn the key to start the engine it only turns about 2~3 seconds and stop, after that the battery indicator flash slowly every time
    I think car is in eco mode active
    cheero's Avatar
    Czech Republic
    eco mode active no problem !!! car normal work, conect via diagnose ecu and read dtc or online data, when no read dtc or online data => immo problem
    clusters's Avatar
    Mar 2015
    Canada
    Key on, is the check engine light working? If not check your powers and grounds to ECU.
    Would not be the first time someone forgot to connect a ground.
    Oct 2010
    Hello again, I tested the key with and without the transponder and when try to start the car without in the display shows Immo-active.
    Anyway I must connect to car’s units if the immovilizer is active or not, I’m using diagbox scanner
    Oct 2010
    Problem solved, bsi was damaged and don’t aplly signal to start bsm
    Thanks for your reply
    Jun 2018
    you have pp2000, autocom ?
    Oct 2010
    Yes, I have
