Results 1 to 14 of 14
    Oct 2017
    Default Simos pcr2.1 writing problem
    Hello to all i have a problem on ecu pcr2.1 , need to do egr off , this my first time to work with pcr2.1 , I connect kess v2 and read ecu id kess give me the ecu is unlocked , i ask my friend because this my first time on pcr2.1 he told me you need to do manuly unlock to be sure the ecu is 100% unlocked .
    i do manual unlock and see that ecu didn’t open before (factory condition) . At this moment told my self impossible this ecu is unlocked from factory.
    Finally: the ecu writing modified file at 100% give ecu writing error .
    when writing ori file , no problem writing full flash file without any problem.
    need to know where is my problem.
    dominik.m's Avatar
    Jun 2009
    POLAND
    Are You have another tool? Like FGTech?
    Oct 2017
    Quote Originally Posted by dominik.m View Post
    Yes , i will tring using galletto, on 100% error writing ecu same as kess
    dominik.m's Avatar
    Jun 2009
    POLAND
    I had similar problem some time ago.
    I used VCP and I write file FRF. Next- I unlock ECU. I read ori file , I did over again , later writing did not make up problem.
    Oct 2017
    i think probleme in your eprom its locked
    dominik.m's Avatar
    Jun 2009
    POLAND
    I think, if ECU does not be unlock , writing ori file is not possible!
    Oct 2017
    Quote Originally Posted by DeSSeD View Post
    Some one told me to restore eeprom ori backup because the ecu is already unlocked, if you repat unlock on unlock the ecu becomes locked.
    is this real ?
    Oct 2017
    The ori backup can write in locked and unlocked mode
    May 2018
    hello
    for pcr2.1
    you have to read flash and eeprom
    eeprom : unlock it
    flash : remove what you want to remove - with winols or swiftec - for ex : dpf egr off
    after you write
    the verry good tool to write on pcr 2.1 is galetto
    good luck
  10. The Following User Says Thank You to docbilandro For This Useful Post:
    DeSSeD (8th June, 2018)
  11. #10
    Oct 2017
    Quote Originally Posted by docbilandro View Post
    hello
    for pcr2.1
    eeprom : unlock it
    after you write
    good luck
    I do on galletto same result.
    my question is , first ecu id check give me the ecu unlock and i do unlock on already unlock is this mistake??
  12. #11
    dominik.m's Avatar
    Jun 2009
    POLAND
    To be maybe so. You unlocked already unlocked ECU.
  13. #12
    Oct 2017
    Unlocked already unlock = the ecu comeback locked ?
  14. #13
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Quote Originally Posted by Mohammedananew View Post
    Yes. When you unlock unlocked ECU it became locked again. Write original EEPROM and write modified flash.
  15. #14
    Mar 2015
    UA
    Hey. When identifying KESS what do you write in this window? Look at the screen.
