Results 1 to 15 of 20
    Dietrich's Avatar
    Oct 2017
    EUROPE
    Default NISSAN QASHQAI 2.0 DIESEL BIG PROBLEM!
    Hello mates,
    The story is:
    One owner of qashqai 2.0 diesel 2007 150ps/110kw (engine code M9R) watched some video and bought chinese mpps 13.
    Then he bought file from someone in the internet and uploaded in the car.
    He made few big mistakes and now car doesn't start.
    Mistake number one - he has a key-less system and he didn't put the metal key into the ignition during writing. Now immo can't see the key even when it's in ignition.
    Mistake number two - mpps 13 can't make injector codes read and he loosed this codes. (that's not a problem, I have launch, autocom, bosch kts, but I can't write it cause of immo fault!)
    The DTC I have for the moment P0611 -injector fault and P1612 - immo fault
    The things I tried :
    - write injector codes via Gallettov54 like renault "injector coder CAN' with key inserted- no result.
    - write injector codes manually with key inserted - always ended with the fault (I know the procedure of writing)
    - insert the key into ignition for 15 minutes with ignition ON - also nothing
    Does any one knows what to do?
    Thanks for advice!
    Have a nice day!
    Sep 2016
    yes. Consult flashing ecu by obd and programing to car, coding injectors and works.
    FILE SERVICE
    Dietrich's Avatar
    Oct 2017
    EUROPE
    I have no Consult tool in my place, and official dealer is 370km away. Any other solutions?
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    The biggest mistake is - MPPS
    DSG TUNING
    File Service
    Dietrich's Avatar
    Oct 2017
    EUROPE
    I agree, but how can I fix his fail? Is it possible?
    maajkii's Avatar
    Mar 2017
    What ecu we talking about? Post more info
    DSG TUNING
    File Service
    Dietrich's Avatar
    Oct 2017
    EUROPE
    Nissan Qashqai 2.0DCI 0281014361 EDC16CP33 1037537826
    maajkii's Avatar
    Mar 2017
    You try to reflash full Bdm?
    DSG TUNING
    File Service
    Dietrich's Avatar
    Oct 2017
    EUROPE
    Quote Originally Posted by maajkii View Post
    Owner doesn't want ECU to be opened. Any chance to make it other way? If not I will just leave it as it is.
    carmageddon's Avatar
    Italy
    who choose how to work/restore on ecu....you or owner????
    if owner : he can go with car in nissan to solve all problem
    if you : then open ecu and as first make backup of all to send here, maybe someone will help you
  11. The Following User Says Thank You to carmageddon For This Useful Post:
    racin-snake (24th January, 2020)
  12. #11
    maajkii's Avatar
    Mar 2017
    Quote Originally Posted by carmageddon View Post
    exacly, what problem with open ecu? Car for shure is after warranty.
    Try find full BDM. Reflash it And you should be able to start a car.
    For shure you can adapt a key than. Problem now is in epprom i think,
    DSG TUNING
    File Service
  13. #12
    Dietrich's Avatar
    Oct 2017
    EUROPE
    what if I download bdm file from ECU, how can I make it work?
    I don't have special tools for keys to extract immo code and in my place no one have it also.
  14. #13
    maajkii's Avatar
    Mar 2017
    Try flash full Bdm And car should start. I think you can adapt key with galletto ( im not shure )
    DSG TUNING
    File Service
  15. #14
    Oct 2017
    U have corupted flash that s all, easy fix via BDM. FIrst read BDM as it is and fix with OBD read.
    after taht car will start and only rev 1500 rpp, and uc an code injectros with diag tool to restore full rpm!
  16. The Following User Says Thank You to autoSP For This Useful Post:
    maajkii (9th June, 2018)
  17. #15
    busaman's Avatar
    suffolk uk
    i have the same problem tried this procedure but will not start
    7.31sec@203.3mph
