Results 1 to 4 of 4
    Jan 2016
    Default RNS 310 FW 0235 --> 0357/ 0358 ?
    are there any news, how to update the RNS 310 from 0235 to 0357 or 0358?
    My RNS had the firmeware 0235 on it, so I made an update to 0351 with one moddified CD (KD01) and the normal 0351.
    By updating with the CD 0357 it makes a downgrade to 0235 again.
    By updating with the CD 0358 it makes a downgrade to 0236.
    I tried to moddify these CD's while deleting the 0235/ 0236 part.
    I also tried to modify them while replacing the 0235/ 0236 part trough 0357/0358 files.
    With HxD I also tried to replace the number of the version, because I thought, that the RNS check that.
    With all these moddified CD's the firmware update gets installed but after installing the firmware the display shows "Software update needed, please insert download data carrier"
    I think there are wrong checksums that make the update fail.
    Maybe the RNS block the update while checking the checksum?
    After that I had to install the KD01 and 0351 again to came on 0351.
    My RNS 310 had some bugs with audio settings. For example by pressing the mute button twice the soundlevel is on "5" no matter what soundlevel adjust before. There is a TPI for this problem. Solution is an update to 0358. So I want to get on this firmware.
    My question: Are there any news how to get a newer firmware as 0351 on RNS 310 if there was 0235 on it?
    Is somebody here who can modify the CD to make that possible? Maybe someone who can modify the checksums and make the 0358 checksum similar to 0236.
    If someone need the CD (0357 or better 0358) to look over it or just so, please contact me.
    Thanks.
    regards
    universal technics's Avatar
    Egypt
    Hello appreciated friend,
    Please check your PM.
    Jun 2020
    Default hi, i need help
    Hi, i've read your post and i had same problem so i'd like to try with 0358 firmware but i can't find it anywhere. Can you help me? For the screen message after installing 0357 insert data carrier i read that you simply have to reinsert the disc and the updating goes on. Thanks for your support
    Jun 2020
    Hi!
    I got the same issue. Im stuck at 0351.
