Results 1 to 15 of 15
    Oct 2015
    Default Iveco Dash pinout and repair
    Hi, I have here a Iveco Daily dash for repair. Fuel and speed gauge doesn't work. I need also pinout.
    Anyone have info for repair this dash??
    waldi1979's Avatar
    Dec 2010
    Green plug:
    1 GND
    17 +12v
    19 +12v
    24 fuel level (resistance to gnd)
    26 fuel reserve (to gnd)
    Blue plug:
    22 speed signal
  3. The Following 9 Users Say Thank You to waldi1979 For This Useful Post:
    asliyucegsm (18th August, 2021), Cesarec (31st March, 2022), eliah (2nd June, 2022), licho (26th May, 2022), magdex (8th October, 2022), Perryking (15th June, 2018), RomanDon (23rd May, 2023), thurgau (8th December, 2021), Zsigubigule (14th April, 2021)
    bidu20's Avatar
    Jun 2016
    fuel = 20 ohm -> Full
    125 ohm -> 1/2
    330 ohm ->empty
    Speed = 170 Hz->60km/h
    your km counter is working?
  5. The Following User Says Thank You to bidu20 For This Useful Post:
    Perryking (17th June, 2018)
  6. #4
    Oct 2015
    No, the counter is not working.
    bidu20's Avatar
    Jun 2016
    do you have a tachopraph?
  8. #6
    Oct 2015
    Quote Originally Posted by bidu20 View Post
    Yes, but not work. Customer says tachograph is disconeected.
    So what do you think about this problem??
    Thanks!
  9. #7
    bidu20's Avatar
    Jun 2016
    and wehn you test it on bench you have same problem?
  10. #8
    Oct 2015
    I power up the dash in bench using this pinout but not power up at all
    Green plug:
    1 GND
    17 +12v
    19 +12v
    Please can you explain me how to test gauges? And how to power up the whole dash? Thanks
  11. The Following User Says Thank You to Perryking For This Useful Post:
  12. #9
    bidu20's Avatar
    Jun 2016
    1 Kl. 31 M7
    2 Klimaanlage seriell
    3 Blinker Anhänger
    4 Blinker Anhänger
    5 Alternator
    6 Motoröldruck tief
    7 Handbremse angezogen
    8 Getriebeöltemp. hoch
    9 Nebenantrieb Ein
    10 EGR Warnleuchte
    11 Immobilizer
    12 Retarder eingeschaltet
    13 Airbag Kl. 15
    14 Airbag
    15 Sitzheizung eingeschaltet
    16 Versorgung Impulse
    17 Kl. 15
    18 Kl. 50
    19 Kl. 30
    20 Standlicht Beleuchtung Kombi +Kl.58
    21 Motorölstand tief
    22 Motorölstandsensor tief
    23 MS7 Kl. 31
    24 Tank 330 Ω = leer
    125 Ω = ½
    20 Ω = voll
    25 Kühlwassertemp. 60°C = 540 Ω
    80°C = 250 Ω
    100°C = 120Ω
    26 Tankstand
    27 Kühlwassertemp. hoch
    28 Bremsverschleiss
    29 Motorölstand in Hydrolenkung niedrig
    30 Notöffner blockiert
    31 Notöffner aktiv
    32 Tür offen
    i test it with this. Does the instrument a test when it is turned on? (more lamps, you hear the gauges turn to zero?)
  13. The Following User Says Thank You to bidu20 For This Useful Post:
    yokazik (28th June, 2018)
  14. #10
    Oct 2015
    No, no sound from gauges, no more lamps. In car, dash power up all even the reserve fuel light (reserve fuel light is on always), but fuel gauge and speed gauge not work, and in screen counter km doesn't change.
  15. #11
    Oct 2015
    I tried with 470 ohm resistor to GND in pin 24, fuel gauge doesnt move.
  16. #12
    bidu20's Avatar
    Jun 2016
    i think your dash is ok. problem is with tachograph or speed sensor from tachograph. fuel-gauge maybe works not when you have problem with speed signal
  17. #13
    Oct 2015
    Ok, I´ll see in the van.
  18. #14
    bidu20's Avatar
    Jun 2016
    Did you find the problem?
  19. #15
    Aug 2020
    1 Kl. 31 M7
    3 Blinker Anhänger
    4 Blinker Anhänger
    5 Alternator
    6 Motoröldruck tief
    9 Nebenantrieb Ein
    10 EGR Warnleuchte
    11 Immobilizer
    13 Airbag Kl. 15
    14 Airbag
    17 Kl. 15
    18 Kl. 50
    19 Kl. 30
    23 MS7 Kl. 31
    125 Ω = ½
    20 Ω = voll
    80°C = 250 Ω
    100°C = 120Ω
    26 Tankstand
    28 Bremsverschleiss
    31 Notöffner aktiv
    32 Tür offen
    Hi Guys, wondering if anyone can help! I have a rev counter issue on my Iveco, I know the power comes from the green plug but does anyone have the pin outs for it? Thanks in advance!!
