Results 1 to 15 of 19
    Dec 2015
    Default FRM3 d-flash programmation error message
    I use upa since a short time and i have a bad issue.
    I read a MC9s12xeq384 from a BMW FRM3. i read it without problem (p-flash, d-flash and eep). Eep was corrupted ans i restore the file with d-flash data. i try to format D-flash and eep to write it but i can't write d-flash, i have this message :
    Detected Oscillator Frequency: 8000kHz
    FSTAT($A0) Register Error
    Programming: 1 Errors Found Device: MC9S12XEQ384 Range: 0 - 7FFF
    and no writing
    but when i try to write eep, no problem
    Programming: Success Device: MC9S12XEQ384 Range: 0 - FFF
    I hope that someone could help me with this issue or give me some advises?
    thanks for your help
    Jun 2016
    Is this on UPA
    Sent from my Redmi Note 4 using Tapatalk
    Dec 2015
    Is this on UPA? Sorry but what's your question..... yes, i use upa as i said in the first post
    Jun 2016
    Do you have any other tool like smoke vvdi prog or xprog
    Dec 2015
    Yes i have xprog but it won't program d-flash too
    Jun 2016
    Some times UPA cant do the job,
    but xprog did it 100/100 times...
    please check connection care fully,
    if its not work maybe FRM faulty
    Europe
    You should not program D-flash, you should program the eee area.
    If you erase the eee area it asks how much blocks you want to assign, assign all blocks to eee so you get 4KiB eee and 0 bytes D-flash.
    Is this a clone or original UPA?
    Dec 2015
    Hi, sorry for late answer, my problem is not solved for now. I have original UPA and xprog clone.
    "If you erase the eee area it asks how much blocks you want to assign, assign all blocks to eee so you get 4KiB eee and 0 bytes D-flash."
    That's what i try, but if you partition d-flash and eee, you erase the two, i try to write each separately with no prob but i can't write both. I always have the error message.
    Europe
    Quote Originally Posted by Zhed View Post
    But WHY do you want to program D-flash???? You can't and you shouldn't
    What is your problem?
    Dec 2015
    I don't want to program d-flash, i just want to write corrected eep file. So when i partition 4kb for eep, it erase also d-flash, how to rewrite both in mcu? it looks not possible....or do i miss something
    Gavra's Avatar
    Belgrade/Melbourne
    My mistake, go back to making cookies......
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
    Dec 2015
    very relevant answer......
  13. #13
    Newbie vadja777's Avatar
    Jul 2016
    Daugavpils
    Don't worry. I'll try to help you. I use to do this xprog-m programmer. Fisrtly, You must erase EEE area with parameters of eeprom:number of sectors for eeprom = 16
    d-flash = 0
    eeprom = 4096.
    And then you must write Your data in EEE area.
  14. The Following 2 Users Say Thank You to vadja777 For This Useful Post:
    Freelander99 (2nd September, 2022), Zhed (10th July, 2018)
  15. #14
    Dec 2015
    Quote Originally Posted by vadja777 View Post
    d-flash = 0
    eeprom = 4096.
    Thanks for your advise but i finally found my mistake my self. Misunderstanding of partion for eee and d-flash but now all is ok.
    Now, I can go to make some cookies...
  16. The Following User Says Thank You to Zhed For This Useful Post:
    talk2idris (11th July, 2018)
  17. #15
    Nov 2018
    I have the same problem could you help me
