eb5t-14b321-aa explorer
please, use magic buttons reputation+thanks.
Best regards. rvtecs
Errors before clear ?
Scripts for Multi-PROG
Best regards.
Dragon
read on table carprotool
B0001:13-8B - Driver Frontal Stage 1 Deployment Control
B0010:13-8B - Passenger Frontal Stage 1 Deployment Control
B007E:13-8B - Driver Seatbelt Pretensioner „C“ Deployment Control
B007F:13-8B - Passenger Seatbelt Pretensioner „C“ Deployment Control
B0002:13-8B - Driver Frontal Stage 2 Deployment Control
B0011:13-8B - Passenger Frontal Stage 2 Deployment Control
B1404:13-8B - Driver Power Window Down Circuit Open
B1407:13-8B - Driver Power Window Up Circuit Open
B1405:13-8B - Driver Power Window Down Circuit Short To Battery
B1408:13-8B - Driver Power Window Up Circuit Short To Battery
B0070:13-8B - Driver Seatbelt Pretensioner Deployment Control
B0072:13-8B - Passenger Seatbelt Pretensioner „A“ Deployment Control
B0082:13-8B - Passenger Seatbelt Load Limiter Deployment Control
B0005:13-8B - Collapsible Steering Column Deployment Control
B11CF:13-8B - Passenger Frontal AirBag Cannister Vent
B141B:13-8B - Passenger Power Window Motor Stalled
B0013:13-8B - Passenger Knee Bolster Deployment Control
B141C:13-8B - Right Rear Power Window Motor Stalled
B0050:13-8B - Driver Seatbelt Sensor
B0052:13-8B - Passenger Seatbelt Sensor
B00B5:13-8B - Driver Seat Track Position Restraints Sensor
B00C5:13-8B - Passenger Seat Track Position Restraints Sensor
B140C:13-8B - Central Lock Short to Ground - Rear Nodes
B140D:13-8B - Unknown Error
U0100:00-8B - Lost Communication With ECM/PCM
U0140:00-8B - Lost Communication With Body Control Module (GEM)
U0154:00-8B - Lost Communication With Restraints Occupant Classification System Module (OCS)
U0155:00-8B - Lost Communication With Instrument Panel Cluster (IC) Control Module
U0253:00-0B - Lost Communication With Accessory Protocol Interface Module
B11D8:14-0B - Restraint Event Notification
B1413:93-8B - Driver Power Window Motor Circuit Short To Ground
B1417:93-8B - Power Window LR Motor Circuit Short To Ground
B1419:93-8B - Passenger Power Window Motor Circuit Open
B1414:93-8B - Power Window LR Motor Circuit Failure
B1415:93-8B - Power Window LR Motor Circuit Open
B1418:93-8B - Passenger Power Window Motor Circuit Failure
U0028:08-0B - Vehicle Communication Bus A
U3000:49-8B - Control Module
U3000 bad ....no crash error ...
Best regards.
Dragon
