Results 1 to 15 of 17
    Jul 2018
    Default Fiat Stilo - remote problem
    Hi, I have problem with remote in key (fiat stilo 2005, 1.9 120hp). Key work normal but remote don't work. There send some signal (check in radio), diode lighting but no open car. Can someone help me?
    Ps. Sorry but my English is poor.
    metalik's Avatar
    Mar 2012
    Program remote with diagnostics tool.
    Jul 2018
    Fiat ecu scan can't do that.
    Aug 2013
    Macedonia
    For remote learn you need multiecuscan + pin code from the car
    Jul 2018
    I try fes and mes but I can't see there programming function.
    autochei's Avatar
    Mar 2013
    romania
    sbb u can use learn transponder and in the final sbb ask u if u wonna program remote
    lpf01's Avatar
    Oct 2013
    Quote Originally Posted by thom1984 View Post
    Its in the BSI menu
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
    Aug 2015
    multiecuscan can do it, sbb also after tranponder programming...
    Jul 2018
    Yes, you're right. I had unregister version MES. I will check today full version.
    Thanks guys.
    Bllinda's Avatar
    Baltic
    What is fiat's original program name?
    today
    A topic that interests me
    szengen's Avatar
    Jan 2017
    stilo = ducato remote: stilo remote = sbb + multiscan, ducato remote delhphi clone, non sbb non multiscan, program stilo remote sbb ok, multiscan ok, ducato nain, ducato program remote delphi clone ok, algorytm ok
    stilo remote=sbb, multiscan
    ducato remote = delphi clone (multiscan (multiplexer pin obd)
    remote control device, can be from scrap, provided we have a newly programmed transponder
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
    Jul 2018
    It's not good Multiscan works but after entering the code from the card, program shows the wrong code.
    Can I read the code from somewhere??
  13. #13
    jodge's Avatar
    Mar 2017
    From the BSI
    It depends the market some modell build with marelli some modells with delphi
    Marelli = HC912DG128
    Delphi = 93C66
  14. #14
    szengen's Avatar
    Jan 2017
    If you give me a recipe for Ford Transit 2016, I will give you a recipe for Fiat Stlo,although you have it in earlier posts,
    The stilo ducato remote control works only after 20 seconds
  15. #15
    Jul 2018
    Quote Originally Posted by jodge View Post
    From the BSI
    Delphi = 93C66
    I will read it with eeprom reader?
