Results 1 to 3 of 3
    Mar 2012
    Default Ford Focus 2013 U0120 fault code
    hy. someone could gave a idea about this error? Ford Focus 1.6 105hp EcoNetic 2014 Fault code U0120. i change alternator...nothing, i check wires and it is ok. from alternator to ecu has one wire and is ok. at one moment it work but after 30min again error. it has 13.8 when is error and 14.2 when is work
    Jun 2013
    Test The aku
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
    Mar 2012
    i made it. it was litle motor who command the flaps in front of intercooler. it was in short to ground
