Page 44 of 44 FirstFirst ... 34394041424344
Results 646 to 659 of 659
  1. #646
    May 2020
    https://youtube.com/shorts/WE-VNwBNqg0?feature=share
    OBDstar X300 pro4 2013 MQB Continental cluster reading FAIL
    I was not able to come to try it personally, but I connected with TeamViewer to the tablet and tried to do it while my friend recorded the eeprom reading attempt.
    We tried with VVDI2 after this and it read it successfully. It was Continental cluster, so we assume that the latest update to VW software in OBDstar messed things up.
  2. #647
    vialli's Avatar
    Aug 2018
    Romania
    Does this key programmer also work when you do not have a valid subscription?
    About 5 months ago I was successful with a proxy key for the 2018 Opel Insignia 2 and this week I failed for a 2019 Insignia 2!!!
    I was successful with Autel in the end, I found the security code with OBDSTAR, however, Autel failed to find the security code...
    I don't know what to believe, whether it's because the subscription is not valid or just a version bug???!!!
    Have you had such surprises of not being successful outside the subscription and during its validity you were successful?
  3. #648
    May 2020
    Quote Originally Posted by vialli View Post
    Its not the subscription, they simply ruined the device woth newer updates.
    For example continental MQB adding keys was working perfectly fine, but it was broken about 4 5 months ago. When you try to read immo data it just goes back to previous menu...
    Don't expect it to get better, I only paid for new updates to get moto immo functions...
  4. #649
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by turismou View Post
    Maybe I'm getting paranoid, but I still have the feeling that it's bad intention and manipulation to pay for the subscription
  5. #650
    May 2020
    I understand what you mean, but I'm telling you, buying new updates breaks things more than getting fixed. Better to invest in other tools atm.
  6. #651
    Aug 2023
    Hello, i have ms80 std and want to program a new piaggio key but when i plug p001 programmer i get the error seek file failed
    Verzonden vanaf mijn iPhone met Tapatalk
  7. #652
    Someone succeed to do akl on Audi A4 B8 2009 bcm2 with nec and 95320?
    Cannot read any data on obd.
    Did not connect.
    On bench bcm can be reading,but readout data are not useable for Obdstar x300 dp
    It sayata Invalid.
    On the other thread which i open Lupu Sandu give CS for programming manually
    But i don't found any solution for Obdstar to do it.
  8. #653
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by sepistar View Post
    Did not connect.
    It sayata Invalid.
    You need VVDI2 to finish the job
    What you read with vvdi prog (flash+eprom) you use in VVDI2
    Special function>BCM2 dump tool>Decode and save BCM2 immo data
    Then Key learn>5th immo system>Make dealer key>Key learning and that's it
  9. The Following User Says Thank You to vialli For This Useful Post:
    sepistar (21st October, 2023)
  10. #654
    Fallen's Avatar
    Quote Originally Posted by djollie View Post
    tablet freezes on startup at obdstar logo...apparently requires boot files on sd card to repair.
    How did you go with this?
    Mine has the same problem.
  11. #655
    Sep 2013
    before one year I was able to do Fiat grande punto now not work .Renault clio 4 make before dealer key now not working some rice are coming to updates
  12. #656
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by holbi1 View Post
    What Renault software version did you use?
  13. #657
    Sep 2013
    now I use last one but mabe six month ago i got clio 4 and wont make pecoded
  14. #658
    fuzz1's Avatar
    Jul 2019
    Obdstar breaks stuff previously working with updates
  15. #659
    ivanrpm's Avatar
    costa rica
    Hi guys, I have X300 ODOMASTER, and I need to modify km for Tacoma 2021, there is inside R7F701418, the x300 reads ok but the calc is wrong or the adress is not correct to modify, does someone have done this car before with this tool?
    Many thanks
    Best Regards
    ​THANKS+REPUTATION
