Results 1 to 13 of 13
    Jul 2018
    Panama
    Default Skoda Octavia 1.8T AGU - K04-001 tuning
    Hi guys is there anyone who can help me to upgrade my power?
    My specs are:
    - ECU Bosch M 3.8.3, Audi/VW Part # 06A906018CG
    - Engine code: AGU (Drive by cable)
    My actual setup is:
    - Stage 1 ECU remap, 190 hp/320Nm Immo Off
    - 14 lbs flywheel single mass, VR6 clutch
    - K04-001 turbo
    - Ported exhaust manifold (30% more flow)
    - Silicone turbo inlet hose (TIP)
    - VR6 MAF housing
    - Upgraded DV, Forge DV008
    - 3" (76mm) downpipe and catback
    - 3" (76mm) Flowmaster Hi flow catalytic converter
    - 3" (76mm) Magnaflow resonator and race muffler (direct).
    - Short Ram intake with K&N filter
    - Front mount intercooler 28" x 7" x 2.5" (711.2 x 177.8 x 63.5 mm)
    - 4 pin TFSI coil pack upgrade
    - Upgraded Fuel pump flow to 340 lph (@ 43 PSI)
    - Injectors installed: stock 205cc @ 4 bar (I have 1 set of Bosch 0 280 150 431, Saab red top injectors to be installed).
    - Dogbone poly insert (70A durometer).
    - Bilstein sport suspension
    - Neuspeed sport springs
    Right now the car runs incredible, but I want get the best performance of all my hardware.
    Regards.
    Jul 2018
    Panama
    This car was a payment of my friend who own me some money. These pictures are from before, during and after the tune-up of the car.
    This is a "low budget" project, so all the components replaced were purchased on sales, specials offers and some cases second hand parts.
    What I received.
    ECU part number
    We started the project.
    The old 3 pins ignition coils.
    Jul 2018
    Panama
    Ignition coils Bosch branded, I chosen the used in the Audi R8 (red ones).
    eBay provided - 3" Down pipe USD $60, Intercooler USD $60, Intercooler piping kit with clamps and silicone hoses USD $100. Just must research patiently.
    3" exhaust system.
    Decat downpipe (first installation)
    Jul 2018
    Panama
    Some painting for better looks.
    Intercooler piping - attaching the fitting for N75 valve (eBay purchased, doesn't bring this fitting).
    Intercooler mounting - easiest than I imagined.
    Engine harness and ignition coils upgraded from 3 to 4 pins.
    Ready for the first start.
    Jul 2018
    Panama
    Almost done...
    Wheels: Niche Verona 17" - Tires 235/45-R17. Daily use setup.
    Maxxis Victra ZR9 195/50-R15, TRACK TIRES (were a donation).
    Skoda Octavia 2 (1Z) steering wheel retrofit.
    Jul 2018
    Panama
    Mesh/Grille modification.
    Halogen to projector Headlight upgrade.
    LED cluster lights replace.
    Apsik's Avatar
    Mar 2015
    just behind you
    Quote Originally Posted by nosa View Post
    My specs are:
    Regards.
    First off all change the engine management to wideband ME7.5 ... or get yourself wideband AFR meter. Otherwise it's hard to optimaly tune ME3.8
    If you find my post helpful please hit Thanks button.
    You can also hit Reputation button if you are kind enough.
  8. The Following User Says Thank You to Apsik For This Useful Post:
    nosa (12th August, 2018)
    Aug 2012
    Quote Originally Posted by Apsik View Post
    Its not hard but he must Unterstand
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  10. #9
    Jul 2018
    Panama
    So if I understand, I must use the AFR meter to check the optimal mix when I'm mapping?. (kepping ECU Bosch M 3.8.3)
    I'm new in this of ECU tuning/mapping.
  11. #10
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    For a beginner, the petrol engine modifications are very difficult. Your old type of ecu must be done through the programmer. So it's better to find someone who has an OLS300 emulator and can do a good remap.
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
  12. The Following User Says Thank You to raceshadow For This Useful Post:
    ascotauto (5th June, 2024)
  13. #11
    Apsik's Avatar
    Mar 2015
    just behind you
    Quote Originally Posted by raceshadow View Post
    AGU ECU can be flashed with MPPS.
    I think finding someone with OLS300 in Panama is very close to "impossible"
  14. The Following User Says Thank You to Apsik For This Useful Post:
    teerak2uk (16th October, 2018)
  15. #12
    Jul 2018
    Panama
    Thanks for the information .
    I was researching and found than my specific ECU part number (Bosch M 3.8.3, Audi/VW Part # *06A906018CG- 0 261 206 518 - Bosch M3.8.3 - OBDII not CAN - 1.8L R4/5VT MOTR HS D02 - German made 2002 VW Golf GTI 4 doors 1.8T AGU engine ) could be tuned through the OBD2 port.
    I have VAS 5054a tool, it will work with the MPPS?. Any of you eared or know something about this?.
  16. The Following User Says Thank You to nosa For This Useful Post:
    MrAbsinth (10th November, 2018)
  17. #13
    Nov 2018
    Sweden
    This one you will have to remap MPPS V13 282962624961
    https://www.ebay.com/sch/i.html?_fro...24961&_sacat=0
