Results 1 to 9 of 9
    Jul 2018
    Default New Arrival ADVANCED DIAGNOSTICS SMART PRO KEY PROGRAMMER AD2000
    The Advanced Diagnostic Smart Pro is a state-of-the-art vehicle key programmer that provides fast, easy and intuitive programming via the graphical user interface. Software is driven by Info Quest, the Advanced Diagnostics online key programming database with information for over 5000 vehicles; covering most makes and model worldwide. Expertly engineered with high quality components ensures you of high security standards and outstanding performance. The customized operating system has been designed and developed by Advanced Diagnostics; the foremost authority in vehicle key programming.
    High Performance Hybrid
    The Smart Pro key programmer is a high-performance hybrid OBD key programmer with an all-in-one solution. This simply means that you have the flexibility to customize based on your needs; Pay-As-You-Go, use Unlimited Token Plan and/or Purchase Software.
    Fast Programming Procedure
    The powerful quad core processor, new hardware and software architecture allows you to work smarter and save time. By integrating key programming and PIN reading functions into one step (manufacturer dependent), the programming process is significantly faster.
    Simplified Operations – Streamlined Procedures
    The user interface can be customized to the users’ preferences, for example select the manufacturers list or grid view mode. The color touch screen guides the user through a simple step-by-step sequence
    for all the key programming functions and procedures. Smart Pro is portable, intuitive and unique with useful features like an expansion port for the Smart Aerial, no more dongles or smartcard required.
    Individual software updates are not dependent on previously released software versions.
    Powered by Info Quest (IQ)
    The vehicle data is driven by Info Quest which represents 10 years of automotive data collected by Advanced Diagnostics and tailored to the AD USA application guides for the North American market. The IQ database contains vehicle OBD port location and key type images, VIN and engine codes, plus programming tips that provide the locksmith all the essential information required for key and remote
    programming on one screen and without using a PC.
    Extensive Functionality
    Program transponder keys, proximity fobs, and remotes for cars including PIN reading for various manufacturers using the latest technology. The user interface is icon driven and provides access to extensive functions like ECU identification, read & clear fault codes (manufacturer dependent),
    previously programmed vehicles, and much more. Supports multiple languages; simply select and set.
    Guided Updating Procedure
    Simple and easy updating via WiFi with step-by-step procedures to guide the user. The home screen update” button will display the available software update(s). The Smart Pro can also be connected to a PC with the supplied USB cable to download any new software or security patches. The time for
    updating has been streamlined to provide faster functionality.
    Customized Purchase Options
    The Smart Pro is a versatile and unique vehicle transponder key programmer offering you a tailored and flexible programming solution. You can buy software kits or individual software modules for frequently programmed vehicles and then use tokens or buy 24hr UTP (unlimited token plan) packs on less common vehicles. This hybrid solution transforms the Smart Pro into a user-friendly device, providing 100% coverage of the current Advanced Diagnostics software modules available based on your needs.
    Smart Pro includes 6 months FREE UTP. After this period, you can choose any of the 5 following options. Upgrading or changing to different levels is available and using selected options simultaneously is possible which makes Smart Pro a true hybrid key programmer.
    Key Features
    • All-in-one hybrid solution means you can Pay-As-You-Go, Use Unlimited Token Plan and/or Purchase Software
    • Program transponder keys, proximity and remote keyless entry
    • Integrated security – no dongles or smartcard required
    • Hyundai / Kia ADS 190SD and Nissan ADS 198SD included FREE with UTP or with token use
    • Compatible with the Smart Aerial
    • Fast programming
    • Free 6 months unlimited use
    • Fast updates for software modules individually via Wifi or PC
    • Highly secure and customized operating system
    • Info Quest vehicle database integrated (over 5000 vehicles)
    • Icon driven user interface with easy to use vehicle menu search
    • Intuitive touch screen user interface
    • WiFi and Bluetooth connectivity
    • Multiple language support
    • Internal battery with 2 hrs stand-alone use
    • Battery backup in the event of a power disruption
    • EOBD read & clear faults (manufacturer dependent)
    • 2-year warranty
    Includes:
    • Six (6) Months Free UTP
    • OBD Master Cable, Mains Cable & Charger
    • USB Operating Manual
    • Hard Body Carry Case
    • 2 Years Warranty
    Technical Specifications
    Power 120v main plug for charging
    Weight 11 kg / 6.4 lbs
    Dimensions 12.7” W x 2.6” D x 8” H (322mm x 203mm x 68mm)
    Battery Lithium-ion Battery, 2 hrs standalone use – chargeable via vehicle or
    main connection
    Memory 2GB RAM
    Storage 32GB SSD
    Processor Quad core processor
    User Interface Graphic driven touch screen
    Screen 10.1” (256.5mm) full color (LCD 1280 x 800) PCAP touch panel
    Vehicle Support 12v
    Ports USB Type A & B, Expansion port, Headphone jack, 50 way vehicle connector,
    DC Power
    Wifi 802.11a / b / g /n
    Bluetooth 4.1 Compliance
    Storage Temperature -4°F to 122°F (-20c to 50c)
    Operating Temperature 23°F to 104°F (- 5c to 40c)
    Guys Did some one Test this device From tlkeys ?!
    ray-ray's Avatar
    Buy the hardware you don’t own it (lease item, with a timer).
    Pay-As-Go Token Base $30-40 each time you use it.
    unlimited token use $320.00 month charge.
    buy the software per make and model $900. Or $700. Each
    the smart Pro is a heavy 7lbs. Brick that will eat a hole in your profit. It’s time to show AD/Ilco that there are better solutions out in the market.
  3. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    samy8888 (11th April, 2019), SHD22 (17th June, 2023)
    ibratex's Avatar
    Jul 2015
    angola
    but the functions are Always in advanced products garenteed and correctly functionable .. as far as i know that this one can push dodge family pin till 2017 .. every time i buy is 40 to 60 usd ... that is 1 of the new functions that i know so maybe more money but its more stable and new module in a great reputation firm ... thanks
    Sent from my SM-G935F using Tapatalk
    ghostrider72's Avatar
    Jul 2012
    UK
    Ive seen that in action on one of the exhibitions recently. Works good. But price-wise disaster.
    ray-ray's Avatar
    No bmw, no jaguar, no rangerover even thou the research & development is Base in the UK.
    keymax's Avatar
    Quote Originally Posted by ray-ray View Post
    Yeah and ask all the people who still have their old trade in machines still. This thing is a pig and the development has been at a snails pace for the last 5 years. As a former beta tester I can tell you that they are quick to market with unproven tech. Too many tools on the market for a fraction of the cost and with more capabilities. The way of the all in one tool is dangerous too. I don’t want my key programmer to be my eeprom reader and chip precoder to be the same tool. If it fails you are dead in the water on all jobs. And with a 6 week turn around time on repairs their customer service sucks.
    ray-ray's Avatar
    That’s from a beta tester..
    I start with the tcl1 upgraded to a tcode then move to the T-Code Pro Red. I paid for all my software
    last year they scrambled my unit so it doesn’t program correctly.
    keymax's Avatar
    Sucks having spent so much money upgrading and testing for them only to see your competition or even your customers get the same for a fraction of the cost. When AD started selling directly to dealers and repair shops (or shoe repairers for the UK crowd) it’s clear to see they wanted their backs scratched when they were struggling but never reciprocated. The MVP was the first big “~~~~ you” and we’ve been bending over since.
  10. #9
    Feb 2021
    Quote Originally Posted by keymax View Post
    yup, lets see what CHINA has to say about this..........thinking
