Page 2 of 29 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 435
  1. #16
    Oct 2018
    Quote Originally Posted by dopsleutel13 View Post
    Hi , wat is the problem ? (activation from minhqp is 2016.0 !!!
    If you get the fault ' wrong hardware" or similair then you have not removed old install files !!
    I will check this. I had 2015 R3 installed but now i removed it from PC but on 2016 which I have activated files not working.
    I will let You guys know after downloading program from the link.
  2. #17
    Oct 2018
    Try this 2016.0 Cars and ask again after install .
    Ok, I installed Delphi 2016 from the link and this is the new file activation.
  3. #18
    dopsleutel13's Avatar
    Dutch
    Quote Originally Posted by alyn View Post
    Can anybody help me to get activation tool or activation file for Delphi auto com Program 2016
    sn 100251
    hd EGDFZJFAVQED
    ver 2.13.3
    Activated goodluck
  4. The Following 2 Users Say Thank You to dopsleutel13 For This Useful Post:
    hilfe (28th October, 2018), Senna22 (8th November, 2020)
  5. #19
    Dutch
    Activated Good luck
  6. The Following User Says Thank You to dopsleutel13 For This Useful Post:
  7. #20
    Oct 2018
    I always have the luck for this... It's not working. I got the message: Operation failed Please check that installed version is valid for your type of VCI.
  8. #21
    Jul 2017
    Hello buddy, can you describe which files should be removed windows xp? I have a problem too.
  9. #22
    Dutch
    Quote Originally Posted by hilfe View Post
    You have the error by Activation: Operation failed Please check thats installed version is vaild for you type of VCI.
    Proceed according to the following instructions:
    Delete the following folder: Attention the Folder is Hidden
    System Windows XP
    C:\Programs\Autocom
    C:\Programs\Delphi
    C:\Documents and Settings\All Users\Application Data\Autocom
    C:\Documents and Settings\All Users\Application Data\Delphi
    C:\Documents and Settings\**USER**\Application Data\Autocom
    C:\Documents and Settings\**USER**\Application Data\Delphi
    C:\Documents and Settings\**USER**\Application Data\Microsoft\SystemCertificates\My
    C:\Documents and Settings\Default User\Application Data\Microsoft\SystemCertificates\My
    C:\Documents and Settings\LocalService\Application Data\Microsoft\SystemCertificates\My
    C:\Documents and Settings\NetworkService\Application Data\Microsoft\SystemCertificates\My
    WINDOWS 7 & 8:
    C:\Programsx86\Autocom
    C:\Programsx86\Delphi
    C:\users\**USER**\AppData\Roaming\Delphi
    C:\users\**USER**\AppData\Roaming\Autocom
    C:\users\**USER**\AppData\Roaming\Microsoft\System Certificates\My
    OTHER OS:
    Look similar folders.
    Run CCleaner and clean the registry
    Restart your computer...
    make a new activation for run.
  10. The Following User Says Thank You to dopsleutel13 For This Useful Post:
    Pietrek (28th October, 2018)
  11. #23
    Oct 2018
    I've proceed following steps. But still get the same error.
    I've generated new file activation if it might change anything.
    It's strange because when I installed 2015 R3 before it was done and working without any problems
  12. #24
    Jul 2017
    Maybe we have a bad 2016 installation?
    I am asking for a link to the tested version.
  13. #25
    Dutch
    System Windows XP
    C:\Programs\Autocom
    C:\Programs\Delphi
    WINDOWS 7 & 8:
    OTHER OS:
    The link that I have posted is tested But you have to remove al old installed Autoc/Delpy and extra files as above !!!
  14. #26
    Dutch
    Activated again !
  15. #27
    Jul 2017
    Is the version checked here?
    http://autocom.ucoz.com/down.html
  16. #28
    Dec 2014
    PL
  17. The Following 3 Users Say Thank You to Mario6 For This Useful Post:
    gas43 (12th January, 2019), Pietrek (28th October, 2018), seal777 (26th August, 2020)
  18. #29
    Oct 2018
    Ok. I've done all the steps from instruction one more time as it didn't work... This will be the last try
  19. #30
    Jul 2017
    Please, activate again.
    And one more activation on drive C, the previous one was on drive D
