good evening,
I need the activation of the delphi 2016 file. can someone help me?
good evening,
hi
computer problems, i must change the PC, sorry.
i need activation.
thanks in advance.
tatarcevik (26th February, 2020)
szymonzywiec (17th January, 2019)
Hi friends,
FileActivation.zip
szymonzywiec
Your file. Try and report.
loblancRead post 9. You need download (KV 2016)
https://www.digital-kaos.co.uk/forum...autocom+delphi
Ourbabybo (11th November, 2020)
i have 2016.0 not 2016.R0.
i ask for activation in post #99 and you replied that "License problem or bad file activating".
What is your serial number?
then in post 101 rickard gave me the activation and it worked but I had a problem with the pc and I had to change the computer and in the new pc I had this problem.
in this pc I got the error and since I had had a previous version installed, delete the next files:
C:\Programsx86\Autocom
C:\Programsx86\Delphi
C:\users\**USER**\AppData\Roaming\Delphi
C:\users\**USER**\AppData\Roaming\Autocom
C:\users\**USER**\AppData\Roaming\Microsoft\System Certificates\My
i not deleted autocom folders because i have not them
i cleaned the registry with ccleaner.
restart the computer.
I reinstalled again and asked for the activation again to try again.
anyway, try the files that you tell me but they always gave me error in the activation.
thanks anyway.
i'm waiting for activation again.
hey i remember now one thing.
in the other computer i updated the firmware, can it be the problem?
Serial number: 100251 Hardware key: EGDFZJFAVQED
Product Name: DS150E
Software version: 2.13.3
thanks again
Maybe download the software from here. This is a slightly different version. Ready, not an installation. (360 Diag)
nev 2016.rar
hi
ok i'll try but i don't understand why in the old computer it was working good and in the new one it's not working.
Check if you have Net Framework 3.5 installed. The problem would be if you changed the VCI serial number from 100251 to, for example, 30250
If you download this software, put it on "C" or anywhere. Create a shortcut "main.exe" on the desktop and activate. You can change the look of the icon later.
hi mario6.
thanks for your interest and help.
i have Net Framework 4.7.1 installed and i think that's not the problem because before was working 2015.3 in the last computer.
i have not changed the serial number for sure.
i have gone to download from your .rar but it send me to 2016R1, i don't know if the keygen is good for that version.
There is no 2016.1 or 2016R1 version. There are two versions of 2016.0. One is the installation and the other is Chinese ( 360diag) ready (copy / paste). They have slight differences in appearance. Efficacy in diagnostics is the same. I had both versions on one laptop with OS WIN 8.1. KG operated on both versions. In my opinion, the best are 2013.3 and 2014.2. Next 2014.3, 2015.1 / 2/3 and 2016.0 have errors. They do not support some controllers and do not autoscan ISS.
However, I have on a laptop: 2013.1 Cars, 2014.2 (C, T), 2014.3 (T) and 2016.0 (C, T). They work simultaneously. In all I have a firmware 1423. Plus WOW 5.008.2.
Trucks worked perfectly, cars I got error message:
Operation failed. Please check that installed version is valid for your type of VCI.
I recreated new file.
Dupa123
Your file D... cars 100251
