Results 1 to 5 of 5
    Default 2014 chevy cruze bcm
    2014 chevy cruze.... is there any way to clone he's bcms I cannot program them because I do not have online SPS
    you can read it with vvdi prog flash and eprom . I have done it. if used bcm is same number just clone eprom no need transfer flash
  3. The Following User Says Thank You to cklair For This Useful Post:
    mojomojo (9th August, 2018)
    Jul 2016
    Lebanon
    Just swap 24c16 atmel eeprom and you re good to go car will start windows will roll but radio would be locked
  5. The Following User Says Thank You to skilion290 For This Useful Post:
  6. #4
    Quote Originally Posted by cklair View Post
    did you use v3 of mcu...i have had vvdi prog for over year so hence v1 or v2 i believe of mcu cable
    Quote Originally Posted by skilion290 View Post
    Is the VIN written on here as well as the radio information? the reason I ask because the vvdi prog reads a different(mcu fotget id) chip but I understand that the PIN code/ immo is stored on this 24c16 epp
