Results 1 to 9 of 9
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Default Mercedes ML 320 Cdi Swirl Flaps
    hi... does someone have a solution for swirl flaps for ML 320 cdi...
    SW 1037390892
    Upg. SW P20942P7
    P2513 with conected swirl flaps electronic
    or
    P2530 with disconected swirl flaps electronic
    edc16cp31
    and car is in LIMP Mode
    Andrei2015's Avatar
    Oct 2015
    Default flaps off
    here you have flasp off, pass in PM
    Quote Originally Posted by figani View Post
    SW 1037390892
    Upg. SW P20942P7
    or
    edc16cp31
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
  3. The Following 2 Users Say Thank You to Andrei2015 For This Useful Post:
    figani (1st August, 2018), konq100 (2nd August, 2018)
    figani's Avatar
    Feb 2018
    Car starts and drive until 100 km/h...
    And came fault P2359 pressure of turbo charger less...
    And Limp again...
    Is it possible to deactivate them also...?
    SOLVED, intake was not good assembled... Thanks for fast help by mail....
    Top Poster zapdus's Avatar
    Jan 2017
    And Limp again...
    I have sent a PM but inbox is full
    I also have mercedes ML320
    With flaps, egr and dpf, all ORI
    Why did you take off flaps?
    Some of my friends say the engine sound is better with flaps
    Did your engine sound become worst?
    figani's Avatar
    Feb 2018
    we thought electric motor of flaps has malfunction... and changed it... same dtc was stored...
    so we decided to turn off swirl flaps... but we also turned it off on other car... and the cars are driving...
    and the world is also rotating also longer...
    Dec 2011
    east Europe
    Default Mercedes G320 W463
    Hallo please swirl flaps off ,mercedes G 320 w 463 bosch edc 16cp31.I have P2513 and limp mode,DPF remuver or egr remuver not working good,erase all dtc table.Thanx in advance.
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by Doru Lucian View Post
    Flaps off here.
    press rep and thanks for password
    good luck
    Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
    "clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
    WinOLS 5
    IF helped! Press "Rep & Thanks"!
  9. The Following User Says Thank You to S0nda For This Useful Post:
    Doru Lucian (8th December, 2021)
  10. #8
    Dec 2011
    east Europe
    Thank you mi friend,your file is ok,flaps off and the rest of dtc table stil active.good job.
  11. #9
    S0nda's Avatar
    Nov 2021
    Reading....
    Always welcome, if you need anything else let me know.
    Good luck.
    WinOLS 5
