This tut was amazing but i need to download the file and gotta post so im hoping that this is what im suposed to do
Cheers for the super tute!!!
hey great work on the tutorial but i have a problem. I have installed homebrew and bootmii with no problems, followed all instructions carefully but when i run any tile deleter i cant find ios222,223,249,250. then i try to run wad manager, select all wad files and install i get errors with all of them, i cant retry step 7.1 like it says because theyre not found. any ideas, cheers
thanks for the tut it worked great
Is this still valid and working? I can't seem to dl some of the link .sip files and .rar files.
would this work with a wii that was upgraded with homebrew on it?
I'm having a number of problems guys and I would really appreciate some help. I recently bought a replacement wii (my old one randomly died) and the wii I ordered had homebrew already installed. So, I'm kind of lost as far as knowing what the prior owner has installed/adjusted. I run into a problem right off the bat at step 4, when I try to "Install and patch ios36", I get the following errors (these are the last three lines of dialogue):
"Error: ES_AddTitleStart: (-1035) Title with higher version is already installed.
Error: could not set the revision to 0
ERROR: Downgrade to IOS15 Failed (-1035)
Press any button to continue"
After this, I proceeded to try and install the WADs in a later step, which also ended in error. I'm at a loss for what I should do.. I really appreciate any help.
are you sure your system menu is 4.2?
is there anything on the main screen apart from the homebrew channel? and the normal channels?
have you tried playing a backup to see if it works?
try using this http://www.digital-kaos.co.uk/forums...indows-170234/ it will write you a tutorial and download all the latest files so your mod will be bang up to date.
WHEN ever I try AND delete THOSE ios IT says ERROR???
HELP!!!!!!!!!!!
Thanks for this - Have updated now from 4.2 to 4.3 without problems
Much appreciated
hi i have wii 4.3e using letterbomb and hbc and usb loader gx getting error with gx ios 222 and 223 message can anyone help sorry but im new to softmod
Please and thank
can any one help my I get error 001 wii 4.2u
