Results 1 to 15 of 25
    Jul 2018
    Default LG MediaNav LAN5200WR1
    Hello
    i have a LG medianav withe Dacia Logo and the Restarts!
    i need the NK.bin file for SW Ver: 4.0.2
    i need it to access the WINCE interface.
    BUT i can not find the 4.0.2 version of the NK.bin. i find all versions from 4.0.6 to 9.1.3, but NO 4.0.2
    i tried with all those versions but it will not full boot...white screen with lines and so on.
    PLEASE if anyone have 4.0.2 NK file please share!
    Aug 2018
    Quote Originally Posted by brogdan1001 View Post
    It means that eMMC memory is gone.You can connect 3.3v serial converter to debug socket and select NA.bin ,NB.bin or NK.bin .
    The best solution is solder sd card socket to the pcb.
    Try this NK.bin.
  3. The Following 2 Users Say Thank You to lordabarth For This Useful Post:
    Estefano08 (8th October, 2022), jules815 (15th April, 2022)
    Jul 2018
    Quote Originally Posted by lordabarth View Post
    Try this NK.bin.
    I tried the file you sent me, it reads from USB but nothing happens.
    If i solder the SD slot, where can i get the files that i need to put on the SD? can you share?
    Aug 2018
  6. The Following 10 Users Say Thank You to lordabarth For This Useful Post:
    attilaa0 (27th August, 2018), brogdan1001 (27th August, 2018), BusCan (18th November, 2020), car driver (2nd February, 2019), LabraxDz (26th February, 2019), marcobh5 (12th June, 2020), mr unlocker (11th February, 2023), ouragh (17th March, 2019), RadioChiP (28th August, 2018), skens (19th September, 2024)
    Romania
  8. #6
    Aug 2018
    Desolder resistors r1022 and r1021 witch is CMD and CLK for eMMC.You don't need desolder eMMC.It is glued anyway.
    You must write image on to SD card with for example "win32 disk imager" .
  9. The Following User Says Thank You to lordabarth For This Useful Post:
  10. #7
    Romania
    Thanks ,i forget something,what about the code,if i change with the sd card,i guess emmc contain the code of radio.how i recover it?Thanks!
  11. #8
    Aug 2018
    Code is stored in other type of memory with settings like map area, reverse camera ,VIN and other.
    When you connect serial converter to debug it will show you correct code even if you put wrong one.
  12. The Following User Says Thank You to lordabarth For This Useful Post:
    attilaa0 (28th August, 2018)
  13. #9
    Jul 2018
    Thanks for the image.
    i soldered an SD to the maiboard and flashed the sd with USB image tool with the image provided and the Medianav is alive again!
  14. #10
    Jul 2018
    Quote Originally Posted by attilaa0 View Post
    use this app. it worked for me!
  15. #11
    Romania
    Hi!what about radio code?It changed or remain the old.Thanks!
  16. #12
    Jul 2018
    the code is the same. the old one.
    if you don't have the code, use the app i gave you to scan your serial number from the medianav label on the case. the app will give you the code
  17. The Following User Says Thank You to brogdan1001 For This Useful Post:
  18. #13
    Romania
    Thanks!I can generate the code,but i was confused,you know what memory,or where stored the code on this units?I can say that code not in Mx29lv320 flash.Thanks!
  19. #14
    Aug 2018
    Code is in the flash Mx29lv320 with bootloader and other settings.
  20. #15
    Romania
    Very strange to hear that because i rewrite flash MX29LV320 with another dump and code not changed ,that's why i asked.So code not in MX29LV320.
  21. The Following User Says Thank You to attilaa0 For This Useful Post:
    RadioChiP (29th August, 2018)
