Results 1 to 15 of 19
    Mar 2012
    Default Opel Astra H not starting after replace headlight
    hi guys. i have a opel astra h 1.7 cdti 2009 who not start after i replace a headlight with positive cable out off battery. i have security code, i try to reprogramm key but not crancking. in opcom no fault code, key is reading but car with key in dashboard is blinking
    Apr 2016
    disconnect abs plug and try start car
    Mar 2012
    Still no crank
    Jul 2013
    yorkshire
    need more information,what engine,,,there are 6. Have you checked fuses? F2=80a F30=15a F21=20a K4=starter relay.
    Sep 2015
    You don’t disconnect ABS unit.
    So CAN Line will be interrupted.
    Car don’t start absolutely!
    you have some immo unit (ECM,CIM,IPC) don’t active.
    Global diagnosis please.
    Mar 2012
    i have global diagnosis and opcom say no fault codes. i remove cim and i resolder all pins. i enter in measuring block and say key status ok...programmed, crank allowed but when i rotate key no crank. and car with key is blinking. odd
    the car...opel astra h 2009 1.7cdti z17dtj 81kw. i remeove the headlight and positive cable from battery. after that car start 3 second then stop and car with key blinking
    Mar 2012
    if you want i can put some pictures with status of car. i don`t know how to do immo off maybe will start
    Mar 2012
    error from steering angle is beacause i have not put weel back in cim
    Kic's Avatar
    EU
    Headlight has nothing to do with the ignition/cranking circuit.
    Check and replace the antenna (coil) in the key fob:
    Arrowed: https://ae01.alicdn.com/kf/HTB1t8DQc...pg_220x220.jpg
    Common problem on those keys when blinking key MIL
    Mar 2012
    i know that headlight has nothing to do with this. just i said what i do before not start. now i will change the antena and see what happend. thank you for replys
    Mar 2012
    i change antena but still no. strange is if i try to programm another key is not working. it say programm failed
    Portugal
    Can you diagnose all modules? Are they with "no errors"?
  13. #13
    Mar 2012
    Quote Originally Posted by maucontacto View Post
    all have no errors. thats is strange. it is possible to be CIM?
  14. #14
    Portugal
    Quote Originally Posted by Ionutzllz View Post
    Replace transponder
  15. #15
    Kic's Avatar
    EU
    Transponder could be faulty as maucontacto mentioned but also CIM, pickup coil or wiring.
    Start with the basic: connectors, fuses and do a continuity check with multimeter.
