Results 1 to 8 of 8
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default Renault Clio 2 T5 key clone problem...
    Hello Folks,
    I have problem with cloning T5 transponder key in my Clio2. I put good one key to zedbull mini and EFFi software.
    Good one key shows me 33 Philips with DATA, PCF7930, TYPE 33 REN WR, PINCODE.
    I put another useed, and when try to write these data read above, zedbull mini shows "NO TRANSPONDER" and EFFi
    shows also the same... What is the problem? I have 3 another used keys from another cars, all can't be written.
    This is Sirius32N ECU, UHC with 93C46, key transponder is in chip on small PCB. Please help me to understand how to write data
    to thise 3 used key. All if them have PIN in zedbull mini read description, but no possibility to use this pin in EFFi software.
    Best Regards.
    rafal's Avatar
    UK - PL
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following 2 Users Say Thank You to rafal For This Useful Post:
    doctore (15th August, 2018), WinWoj (15th August, 2018)
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by rafal View Post
    I saw it, thanks, but not all are clear for me. In effi i can't find any step in read,i'll try to read dump from UCH and try to generate key.
    doctore's Avatar
    Nov 2015
    Colorado Denver
    only can generate new t5 not board used
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  6. The Following User Says Thank You to doctore For This Useful Post:
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by doctore View Post
    So there are no possibility to clear T5 data or modyfing 93C46 from UCH to set used key from another car?
    I found 2 pairs of key from 2 cars. So I have 2 UHC's, both with 2 keys.
    One UHC have PIN found in 2 keys and second UHC has another PIN found in his 2 keys...
    As I understand, if I would like to add 3rd key or clone one from 2 existed, only new clear pcb transponder needed.
    EDIT: may I use new empty chip (PCF7946) and solder it to pcb and then program key using 93C46 from UCH??
  8. #6
    doctore's Avatar
    Nov 2015
    Colorado Denver
    only can used set with remote
    or can save your remote for spare parts
  9. The Following User Says Thank You to doctore For This Useful Post:
    lion0304 (16th August, 2018)
  10. #7
    lion0304's Avatar
    Oct 2014
    This Clio 2 Ph1 have only one key data store in UBIC.
    If you want use another set UBIC +Key, just virgin ECU then plug n play.
    If you want to clone another key, use T5 chip clone with Zedbull.
  11. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    doctore (16th August, 2018), WinWoj (16th August, 2018)
  12. #8
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by lion0304 View Post
    I know that I can use T5 chip, the question is what is orginal transponder in this key - coil or 20-pin smd chip??
    Edit: OK, I found that UM9280M is the chip contained transponder. So where can be new one pcb available?
    Brand new key should be possible to add using Clip.
    1. How can i get new transponder with UM9280M chip?
    2. Is it possible to change PIN in this transponder type?
