Results 1 to 14 of 14
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default Smart 450 key sync
    Hi. Maybe anyone give a tip.
    Got smart.
    Owner sais after flat batery no start. In cluster key blink.
    When got car no frequency from key. Replaced battery resolder buttons. Signal ok.
    Trying with fvdi
    Turn ignition on. Conect to sam,turn off,Push lock 2 times. Switch on and push ok on soft. Got messge succesfull
    . But remote still not work and no start.
    In diag error
    B1030 immobiliser counter overflow or no can communication.
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Also noticed that central locking from button on console not work. And there is aftermarket central locking instaled
    Hazzard work only when ignition is on. When key out,not work
    I tried few more tools. It determines vin and that 0 keys programmed.
    When procedure sais turn ignition off before press butyon twrice i get no communication error. I i try program not turn ign off its just gies thrue and sais programming ok. But still 0 keys
    rob h's Avatar
    May 2011
    I used Delphi 2014 on these. 100%
    Also immo problem after battery change.
    Failed with skp900.
    The remote is stored in the sam or zee.
    Could you put this unit in a different car, to see if matching goes well.
    There a 2different 450 systems, these Keys look different.
  4. The Following User Says Thank You to rob h For This Useful Post:
    HeXeN (19th August, 2018)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    No no other car to test.
    Dont have delphi. Autel not have key add option
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    When you start with initialization... the red point starts to flashing or not...?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    No its solid red when ignition is off. And no light when ignition is on.if later push on central butyon its always stays solid no matter ign on or off.
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Ant that button with arrows led is always on when key out. I think maybe problem with sam. As i know 100% fvdi do this car.
    And suspect when soft sais turn ignition off it lost communication with sam. Fvdi not show this but other tools sais fail communication when next step is push button twice after key off.
    figani's Avatar
    Feb 2018
    Don't be angry with me... But you work with FVDi 2014...or 2015...?
    2015 don't do it...
    In any case have sometimes problems, when I first ot delete all dtc's...
    But you're also right... Water damages on SAM... Is standard...
  10. #9
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I have v2015 2018 fly. Tried older and newer soft.
    Ive tried delete dtc buy that b1030 error is currect cant delete.
  11. #10
    figani's Avatar
    Feb 2018
    try to open sam and take look if it´s water damaged... B1030 it´s also possbible can bus fault between dash and sam... just check it...
    in any case can give you other flash/eeprom when you send me label...
  12. The Following User Says Thank You to figani For This Useful Post:
    drugowaz (17th August, 2018)
  13. #11
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I tested all my tools. Now will wait next week will try with mb star. If that not work than problem is in car.
    Say if change new sam need to code it to car match ecu etc?
    From outside on sam ,firewall or carpets dint see not singe sign of water marks
  14. #12
    figani's Avatar
    Feb 2018
    no, friend just built in other sam unit...
    give ignition...
    just make the same, as your are doing with a new key...
    everything done...
    for kilometers other story...
    Smart Forever...
  15. The Following User Says Thank You to figani For This Useful Post:
  16. #13
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Thanks ........
  17. #14
    Jan 2016
    I use mb star to do sync.
    Menu sam> immobilizer> teach again
    Quote Originally Posted by drugowaz View Post
    Envoyé de mon MI PAD 3 en utilisant Tapatalk
