While I don't know about insite 7.3 keygen, I can supply you with DDDL v6.4 and the crack.
DDDL 6.4
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Crack for DDDL 6.4.
This crack does indeed work for v6.4, I have installed it on several machines, but there were some... discrepancies...
If installing on Windows 7, the crack instructions, which are at the bottom of this post, work fine, I had no problems installing it on my Win7 laptop. Windows Vista should behave the same.
Windows XP, however, offered up more of a challenge. After several attempts, the way I found to work consistently was to follow the instructions included with the crack up to the point where you actually run the cracked exe, then enter ten random numbers for the key, once it says it is successfully registered, exit DDDL and reboot. Stop following the crack's instructions right there. Instead: Go to C:\Program Files\ and delete the *ENTIRE* Detroit Diesel folder, reboot, and re-install. The first dialog box to pop up after you run the installer again will want you to completely uninstall any previous versions of DDDL. Do *NOT* remove the "old" version, you overwrite what's already there (I believe the correct answer in this dialog box was "no"). After it finishes installing, reboot, run the program. It will be fully enabled.
I came up with this method through trial and error and have used it successfully to install it on 6 XP machines so far. I would bet this method will work the same with Win 2000.
EDIT: Original crack instructions (not written by me, C/P from another site):
HOW TO INSTALL :
To install on Windows XP and Vista For DDDL 6.4 Crack :
To install on vista or xp follow these instructions. it is a lot
but you MUST follow these direction exact or it WILL NOT work.
Run the install for DDDL 6.4. program
After install DO NOT run the progran. reboot your computer
After reboot (do not run the program at this time)- Go to
c:\program files\detroit diesel\diagnostics\ and copy
"dddl.exe" and paste it to your desktop (make sure the whole
file copies not just a shortcut)
copy the crack dddl.exe file from the download to
right click c:\program files\detroit diesel\diagnostics\dddl.exe
and run as administrator
enter any 10 numbers. the program will now open. let it open
completely.
close the progran and reboot computer
go to c:\program files\detroit diesel\diagnostics\ and
Delete dddl.exe and put the original file from the desktop in
this directory. (do not copy over the cracked dddl.exe it must
be deleted first)
reboot computer again
Now before you run the program you will need to go back
to c:\program files\detroit diesel\diagnostics\ right click
dddl.exe and go to properties. click on compatibilty tab and
make sure run as administrator is checked. click on ok.
Now you are done installing the program and it should run
with no problems. Then install the 6.44ta upgrade.
