Results 1 to 10 of 10
    Default jaguar xf bcm 9s12xet256 read write
    hello
    i have jaguar xf bcm 9s12xet256 mcu
    i read with vvdi & smok read with partition change , but when write d-flash verification error , if i change partition than eeprom verification error
    if i device reset sec , means for unlock device chip than it say ' chip not crypt FE '
    here i attach all photo for infromation & send data also
    if any one please help me
  2. The Following User Says Thank You to maruti For This Useful Post:
    serikpay (28th February, 2023)
  3. #2
    electromech's Avatar
    Behind a large rock
    I am having same issue what would be the partition sizes?
    hello
    when i read d-flash partition error so i change d-flash 128 & than read , than after change eprom 16k than epprom read
    Bllinda's Avatar
    Baltic
    Do you try with xpro.g or up.a?
    today
    A topic that interests me
  6. The Following User Says Thank You to Bllinda For This Useful Post:
    hello
    thanks for reply , today i try with upa , but not ups-s , i dont have x-prog m
  8. #6
    Bllinda's Avatar
    Baltic
    Default pr0gr
    I'm thinking that can do work ....
    today
  9. The Following User Says Thank You to Bllinda For This Useful Post:
    maruti (24th August, 2018)
  10. #7
    Apr 2017
    Default i think
    D-FLASH 4KB
    EEE 2KB
    P-PLASH 256KB
    CAN YOU GIVE ME FULL DATA.
    Here is my E-mail. ehkey@hanmail.net
  11. #8
    hello
    sorry for late reply but my data corupte so this error , i wrote other working module all fine
    thanks for all of u help me
  12. #9
    Usa
    have same issue, if someone can provide pinouts and dumps !
  13. #10
    Sep 2012
    Hi! can someone make a EEE file from currupted D-Flash file?)
    P.S> I made the file myself. How do I record 2 kilobytes correctly? There's 16 kilobytes left.
  14. The Following 3 Users Say Thank You to Alert For This Useful Post:
    Anmed (25th November, 2021), Hayssam1 (25th June, 2021), rtbdiagnostic (21st February, 2022)
