Results 1 to 8 of 8
    Apr 2017
    Default VAG 2.0TDI EDC16U1 with mk6 climate control unit
    We would like to install the golf mk6 climate control unit in a 2005 golf mk5 2.0tdi 16v bkd
    so, the only problem is, that the ac compressor doesn‘t run
    starts for about 1 second and then shutoff
    faultcode: deactivation by ecu via can
    Ecu is a EDC16U1
    i heard, with later ecu, there won‘t be any problems btw problem solved with an update
    but we have latest update on ecu
    any help?
    Germany
    I have exactly the same problem. Skoda octavia with BKD engine/EDC16U1. Installed newer climate controller and compressor doesnt switch on. I think, that ECU and Climate Controller (UDS-protocoll) doesnt communicate correctly. Only Option is the replace ECU by EDC16U31. They are pin compatible. There are BKD engines with EDC16U31. But if you install U31, you will get trouble with glow system. Both ecu´s uses different glow relais. But this is solvable problem I think.
    Greets MR...
    Apr 2017
    Hmm
    EDC16U34 is no option because DPF...
    Have you tested it with edc16u31?
    it would be help to know the differences between U1 and U31/34 for compressor control in flash file
    Germany
    You misunderstand me. You have a Golf5. I took a look into ELSA. The BKD engine was built into Golf to 2009. And because engine is still BKD, of course it is still without DPF. Your car hasnt DPF, too. One look into ETKA -> Golf -> 2009 -> electric parts -> ECU = 03G906021PP is for BKD, no matter DSG or manual transmission. You can code it to DSG or manual. I´m rather sure, that this ecu will let you climate working. And the best is, you can plug it into car, the pinout is the same. Only Glow Time Controller is different. I did not test it myself, but I´m sure, that it will work. I already have the right ecu, but at moment no time to test. Too much work... :-)
    Greets MR...
  5. The Following User Says Thank You to brobble For This Useful Post:
    Galetto (14th September, 2018)
    Apr 2017
    Feedback
    021PP installed
    immo off in e2p and car starts and runs
    no fault codes
    and now ac compresso works
    fine
    Sep 2018
    That sounds good, but what about glow plugs ? Any difference ?
    BR
    M
    May 2012
    It can be fixed in the EDC16U1 file.
    Jul 2018
    Hello, can anyone helps me, i have similar problem, my car is an audi a3 8p, i installed a Q3 climate control but the ac is not working because the ecu not starts the compressor, the ecu is same EDC16U1, what is the solution for this?
