fiat ducato
TRW
01388160080
CLEAR DUMP PLEASE
fiat ducato
TRW
01388160080
CLEAR DUMP PLEASE
help please!!!
bunu bi dene
clear pass pm........
hello mate,i have a problem with a ecu airbag on peugeot boxer 2016 ecu is with memory 25640 smd eeprom ecu 01388160080,and i have a error B0118----configuration error,please can somoane help with this problem?...i dont know how to eliminate this problem...i dont know if it is hardware problem or software problem...the car was not damage in accident.....i will atach the fille
In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
ATTENTION!!!
Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
Thank you!
megabits.
this fille is original,i put another fille from dk(2 files) the same error.....,the file is for sure original...i dont know what to do...please any help..will be apreciate
Check this and report ...
Scripts for Multi-PROG
Best regards.
Dragon
i will atach the VIN number of the car...to se in eeprom ecu airbag if it is the same vin,because i dont know if it is the original ecu of the car.....(i think it is the original)...the vin number is VF3YCTMDC12A98452...,please somoane ceck for me this ?..if is not ok,please repair for me..thks
Hello, Please Clear Crash Fiat Ducato
TRW HH
01388160080
Supplier: 93977-D219
eeprom 95640
Best Regards
[QUOTE = MsCars; 3579663] Ciao, Clear Clear Crash Fiat Ducato
TRW HH
01388160080
Fornitore: 93977-D219
eeprom 95640
Grazie
Cordiali saluti [/ QUOTE]
try this and report.....
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
MsCars (19th May, 2019)
maybe could anyone please check my file from citroen jumper 2015y 25lc640 eeprom . i am getting fault that ecu is faulty but i think it has crash data .
Check the seat belts, or write if something has been changed in the car, the problem is not in the dump, but in the car
Check thdsfdsaae seat belts, or write if something has changed in the car
Hello, bringing old thread up. I had fiat ducato 2015 with airbag error B0100-49 internal error. So I found eeprom for this module online with cleared crash data. Changed few parts in eeprom. Now no faults in airbag module, but other modules see airbag module as not active. I tried writing original eeprom again, and the problem is the same, no fault in airbag module, but other modules see it as not active. Airbag light is on and mileage is flashing. Proxi aligment cannot be done due to airbag module seen as not active. Any advice appreciated, thanks.
Original eeprom link: https://mega.nz/file/H01FkKLK#3eaGHy...10SvQ9E1bK_oLM
Modified eeprom from internet: https://mega.nz/file/P081RAJA#ogEb8K...TWUgOBq0bo_LsU
