Results 1 to 15 of 20
    Sep 2018
    Default steering angle problem for Lexus- any solution!!
    I have a problem with the steering angle sensor for Lexus GS350 2013
    part 89245-30140
    EEPROM s24cs02
    slick_dick's Avatar
    Essex
    whats wrong with the angle sensor?
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  3. The Following User Says Thank You to slick_dick For This Useful Post:
    taxo1965 (5th September, 2023)
    Sep 2018
    Quote Originally Posted by slick_dick View Post
    i got these codes
    c1433
    c1A47 steering angle sensor
    C120E DRS
    C15C1 steering angle sensor
    on the dashboard i got
    - check DRS
    -check VGRS system
    - check BSM system
    - check PCS system
    i think all of them are related to SAS
  5. The Following User Says Thank You to firststep For This Useful Post:
    slick_dick (11th September, 2018)
  6. #4
    Sep 2018
    any help? please
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Check this and report, but you need do procedure I think ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  8. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    firststep (14th September, 2018), taxo1965 (5th September, 2023)
  9. #6
    Sep 2018
    Quote Originally Posted by dragon100 View Post
    i try it it give the "steering angle value between 3072 to 2028 degree !! before it was stuck on 3072
    how to make it 0 degree
  10. #7
    Sep 2018
    in the technical document, the steering angle should be
    Steering Angle Steering angle/
    Min.: -2048.0 deg
    Max.: 2047.0 deg
    with your file, it gives 2028 to 3072 deg!
  11. #8
    superjet's Avatar
    Aug 2018
    try this file and report ,pass by pm.
    If I help, please use the magic button reputation + thank you.
  12. The Following User Says Thank You to superjet For This Useful Post:
  13. #9
    Sep 2018
    Quote Originally Posted by superjet View Post
    what is the password?
  14. #10
    Mar 2020
    hello i have the same problems
    i downloaded it the file but i need the code to unlock it please ,help me
    thank you
  15. #11
    Sep 2018
    Saludos, password please
  16. #12
    credoline's Avatar
    Србија
    Upload yours file and data about SAS.
    Quote Originally Posted by Murillo1 View Post
  17. #13
    Sep 2018
    Default Help please c1433
    parte 89245-30140
    EEPROM s24cs02
  18. #14
    credoline's Avatar
    Србија
    Here is yours file repaired and another from same numbers module repaired.
  19. The Following User Says Thank You to credoline For This Useful Post:
    Murillo1 (8th March, 2022)
  20. #15
    Sep 2018
    Thank you very much for your support
