Results 1 to 8 of 8
    Oct 2017
    Default Renault S3000 megane 2 immo off or virgin needed 95160
    hi guys
    i have a immobilizer fault. ignition turns on but doesn't swing. dash error says immobilizer not active. can anybody help or give me a immo off or a virgine file original file posted bellow 95160 eeprom.
    hope someone can assist
    thanks in advance
    Aug 2016
    put this fille.
  3. The Following User Says Thank You to berciumihai For This Useful Post:
    nonstarterautos (14th September, 2018)
    esse's Avatar
    france
    hi,
    sagem or johnson controle?
  5. The Following User Says Thank You to esse For This Useful Post:
  6. #4
    Oct 2017
    Hi it's a valeo
    esse's Avatar
    france
    virgin 95160
  8. The Following User Says Thank You to esse For This Useful Post:
  9. #6
    Sep 2018
    hi guys, i have same problem. i programmed the eprom chip 95160 with immo off file. now it says in display "immobilizer not active" and does not start. maybe i can try with
    virgin file... or is there any chance to cut the immo line?
  10. #7
    Sep 2018
  11. #8
    Dec 2016
    Hi, you have to repair your Immo who is located in UCH unit, or use immo Julie emulator from www.carlabimmo.com for example.
