Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 128
  1. #31
    Default How to use cheap CH341A programmer for read/write 95xxx Eeproms
    Quote Originally Posted by blackground View Post
    Because the pin 1 is wrong. If you change the connector, you will get device connected.
    What do you mean pin 1 is wrong??which connector?? on programmer?? Do you have a picture. When connecting red led on programmer goes out as soon as i put the clip on the chip. I am using 2 jumpers. I have power on both 3.3 and 5v pins both show 5v.
  2. #32
    May 2016
    take a picture of the front to see the jumpers
  3. #33
    Jan 2016
    thanks , good job!
  4. #34
    i
    Ok I got another ch341a with the same pcb as in this thread. I can get it to connect however I am trying to read a 93S56 it reads everything as FF. Reading 93S56 as a M93C56 it reads but entire memory is blank FF any ideas? Note this is being done in circuit no modification to new programmer on 2 jumpers.
  5. #35
    Aug 2018
    East Pole
    93x and 95x are different type. One is spi, the other one is i2c
  6. The Following User Says Thank You to volorucinski For This Useful Post:
    Louislesinge (19th October, 2020)
  7. #36
    br556hre's Avatar
    93x can also be read with CH341x as 24x i2c chip but you need to connect pins differently to ch341. Look at datasheets for 24xx and 93xx pinout and you will understand how to connect.
    I remember 1 and 8 are the same, other are differently connected and one pin is connected hi or low depending if you have 8 or 16 bit chip. I don't have access to my pc at this time, but you can goolge for it, im sure you will find solution fast.
  8. The Following 2 Users Say Thank You to br556hre For This Useful Post:
    antonypaul (6th August, 2023), Col19 (4th June, 2021)
  9. #37
    Oct 2017
    Just use "AsProgrammer 1.4.1"software.There have 95xx support.I had no issues up to date. https://github.com/nofeletru/UsbAsp-...mmer_1.4.1.zip
  10. The Following 3 Users Say Thank You to odisseys For This Useful Post:
    Col19 (4th June, 2021), rysiek2 (4th November, 2023), seal777 (19th October, 2024)
  11. #38
    br556hre's Avatar
    This guy have 93xx chip that is microwire and require different pin connections.
    Look at this video:
    https://youtu.be/hPKckby54uA
  12. #39
    Quote Originally Posted by odisseys View Post
    Are you using a modified reader/programmer with 2 jumpers?? I ordered another one and its turns out there is 2 o 3 different versions of pcb for this thing i was able to get the same one you guys are using but had no luck reading eeprom in circuit.
  13. #40
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by br556hre View Post
    yes adrianux, 24c32 can be read, no problem. Just take care to connect pin 1 correctly!
    Can you explain what you mean by take care of pin 1?
  14. #41
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by AudiS4 View Post
    Have you shorted the crystal before reading the eeprom in circuit?
  15. #42
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by ferrarikid View Post
    Just wanted to say I really appreciate who made this guide I too was able to read some eeproms with this method. For those doing the mod I know this is self explanatory for some but for me wasn’t strait forward, this is how you do the capacitor mod. Also I added a file you can replace in AsProgrammer to get more types of chipsets in the search Attachment 699646
    Attachment 699644
    I guess you wrote the attachement chipset.zip. Would you mind sharing how you added the extra chipsets?
  16. #43
    fuzz1's Avatar
    Jul 2019
    Here is a link to download a newer asprogrammer
    More chips can be read
    https://drive.google.com/file/d/18JJ...KUzAEgCJo/view
    Your views from this new software most welcome
  17. The Following 5 Users Say Thank You to fuzz1 For This Useful Post:
    antonypaul (6th August, 2023), Col19 (4th June, 2021), eric paris (10th February, 2021), JakaPutra (27th December, 2020), xotta6 (11th April, 2021)
  18. #44
    Newbie JakaPutra's Avatar
    Dec 2020
    its work, nice
    Quote Originally Posted by fuzz1 View Post
  19. The Following User Says Thank You to JakaPutra For This Useful Post:
    stutar (14th November, 2021)
  20. #45
    fuzz1's Avatar
    Jul 2019
    Share the chips you read if possible
