Page 8 of 9 FirstFirst ... 3456789 LastLast
Results 106 to 120 of 128
  1. #106
    Newbie racoxd's Avatar
    Aug 2023
    but then how is this guy doing it? (It's the same car)
    https://youtu.be/oIz-mccrEWA?&t=128
  2. #107
    Aug 2023
    Issue from #99
    SOLVED!
    thanks to user An2pl who advised me to:
    1. isolate pin3 from the clips adapter (pics below)
    2.
    use 3.3v rather than 5v.
    and this did the trick! I successfully read/wrote to the chip to clear the crash data.
    I also tested reading with 5V and it worked too, but 3.3v is recommended for 95640 chips so I'd stick to that.
  3. The Following 2 Users Say Thank You to racoxd For This Useful Post:
    bergekste (13th November, 2024), fuzz1 (3rd October, 2023)
  4. #108
    I did notice that there are more than 1 version of this chip reader the the boards are different. This may be the reason why some work and others don't as the cut trace may be there but serves a different purpose. I ran into this issue recently.
  5. The Following User Says Thank You to AudiS4 For This Useful Post:
    rysiek2 (4th November, 2023)
  6. #109
    Nov 2023
    I would like to thank my colleagues for the substantive discussion.
    It helped me a lot. It turned out that in my case it was enough to use AsProgrammer without any changes to the layout.
  7. #110
    Hello, thank you all for all this information which allowed me to troubleshoot the airbag warning light on a Suzuki Swift.
    The eeprom is a 95160, I didn't touch anything on the CH341A programmer, the latter worked very well with the NeoProgrammer software.
    FYI, I successfully reprogrammed directly with pliers, without unsoldering the eeprom.
    Good day.
  8. #111
    Hallo,
    I need some help with my new CH341A, I want to read a cluster eeprom (24C32/24C64) with the test clamp.
    Are there any information about the installation?
    3,3V or 5V?
    I hope someone could help.
    Thank you
    ~rexdv
  9. #112
    Dec 2023
    Can anyone help me read a chip with asprogrammer 2.1.0.13?
    I've attached a photo of my setup, the chip I need to read is G93LC86C I've tried selecting both microwire M93C86_8bits and M93C86_16bits both produce a microwire ic not responding error. The autodetect button produces a ic not responding error.
    I've tried my programmer in both the 24xx and 25xx slots with no success.
    Chris
  10. #113
    fuzz1's Avatar
    Jul 2019
    My advice is not to read in circuit.
  11. The Following User Says Thank You to fuzz1 For This Useful Post:
    thomp1983 (9th January, 2024)
  12. #114
    Jul 2021
    nzjohn https://www.digital-kaos.co.uk/forums/member.php/746870-nzjohn Hi . Can you please send me the correct pin connection ?
  13. #115
    Jul 2021
    Quote Originally Posted by nzjohn View Post
    To flash 93xxx series eeproms with a CH341, buy some female to male jumper wires. Connections are named on the reverse of your CH341 at the base of the pins. You have 5V, 3.3V, GND, MIOS, MOSI, CS, and CLK. Using jumper wires of 8 colors for ease of use, connect the female ends to the CH341 pins while the other male end runs to your clip or board with the eeprom attached . Eeprom pin 1 connects to CS, Eeprom 2 connects to CLK, Eeprom 3 to MOSI, Eeprom 4 to MIOS, 5 to GND, 6 to 3.3V, and lastly join the wires from Eeprom 7 and 8 together and connect these to your CH341 5V pin. It's best to solder the eeprom to a board but a clip is almost as effective.
    If you can use color coded wires it's easier to check you are connecting to the correct places.
    I'll post clearer pics if anyone has problems. Ch341 can be left exactly as it was delivered. No soldering or additions are required. Leave the yellow jumper exactly on the two pins [as it arrived] on the CH341.
    Remember to check your connections and this will work as I've outlined.
    Good luck
    Any issues..
    Recheck your connections!
    Good luck and all the best.
    .Attachment 791553Attachment 791549
    Hi all . I maked all than nzjohn but dont read. Can maybe somebody say what is wrong ? Thank you
  14. #116
    Dec 2023
    Quote Originally Posted by thomp1983 View Post
    Chris
    So after some time I found out the pin wiring is different for the G93LC86C chip so I need to repin my soic clip.
    Now I've got a dump from the chip what is the best way to read what's in it and edit it, this is for an audi instrument cluster?
    Chris
  15. #117
    Feb 2024
    Thanks for the good explanation on how to use!
  16. #118
    Feb 2021
    NEW ZEALAND
    Use a CH341a programmer to read or write to 93XXX Eeproms UPDATE:
    Only six wires are required to write to 93C66 (plus 93A66) series chips. The connection to 3.3 v is not required, so I've simplified the set up and listed the details below.
    Pin 1 on the 93C66 chip via clip and lead goes to the CH341a pin which is marked underneath as CS, pin 2 to CLK, pin 3 to MOSI, pin 4 MIOS, pin 5 {opposite to 4 in my picture} to GND, then we have 3.3 volts which can be left OFF, lastly connect pin 8 (opposite to pin 1) to the CH 341a 5 V pin.
    The connections on the clip at either end can break, and as they are hidden by black wrap this is very easily overlooked. Go over your connections, test, and re-solder if necessary. This method works so if you have issues, check and double check.
    I apologize for not answering all questions, but I'm no expert and tech questions are best left to more knowledgeable members. The configuration outlined in my post works repeatedly for me without any changes to the CH341a board whatsoever.
    Thanks and all the best! Bad readings are usually caused by bad connections, incorrect chip, or impatience.
    Last edited by nzjohn; 24th February, 2024 at 02:24 AM. Reason: Updated information
  17. #119
    Feb 2024
    Hi, iam trying to program a S93a66 and am able to read the chip but i dont know where the information is stored for the KM, and how to make the required changes. the chip is our of a 2007 Holden Rodeo 2.4 which might be the same as a 2007 Isuzu Dmax 2.4.
    any help would be great
  18. #120
    Mar 2024
