Results 1 to 10 of 10
    Nov 2012
    CRO
    Default PCR 2.1 EEPROM Bricked?
    i have a problem with PCR 2.1. The ecu was unlocked via Galleto Clone. After unlock, the car started normally. But then when i wrote a new map but at 100% i received a error and the car doesn't start anymore. Already tried to put the original map to the ecu but without success. Can it be that the Galleto didn't unlocked the EEPROM in right way?
    Later i make a EEPROM backup with KESS and also tried unlocked it - Task was successfully completed, but i cannot put any map into the ecu.
    With Kess i can identify the ECU:
    SW: 03L906023ML
    SW upg.: 03L906023ML 9970
    Is the EEPROM bricked or i didn't have a good backup? Thanks a lot.
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Write original EEPROM and original flash with KESS.
    If not worked - flash sgo via vag can pro.
    Nov 2012
    CRO
    The problem is that i dont have the original eeprom file.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Put ecu in car, connect galletto, Do not ecu data, but open ori file and write. If eeprom not erased, car will start again
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Nov 2012
    CRO
    Tried, i receive error at 100% when i write the file with Galleto. EEProm is not erased but is somehow locked i think.
    dominik.m's Avatar
    Jun 2009
    POLAND
    Once had similar problem. I tried to repair in different method this.
    Without success. I used vag can pro and reflash ecu with sgo file. Car start.
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Default 03L906023ML 9970
    Program EPROM
    Then the flash with the Galleto
    Good look
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
    Nov 2012
    CRO
    Thanks, i try it later.
    I see by checksum that you unlocked the EEPROM once more? Was the EEPROM not good unlocked?
    Nov 2012
    CRO
    Tried but at ending of writing i receive again this error. Any other solutions?
    Nov 2012
    CRO
    Quote Originally Posted by dominik.m View Post
    Where can I get the sgo file?
