Results 1 to 7 of 7
    Oct 2015
    Default BMW ELV solution
    Hi, I need a solution for BMW Mini red steering light.
    Until now I was using reset cas counters (temporal solution, always fail again), and ELV emulator.
    Now in my country we can not use emulator because the car inspection see if steering lock without keys.
    So what is the solution for this? Is possible to put another ELV from another car and coding? Or any other solution for no more red steering light?
    Top Poster autohaus's Avatar
    Jul 2013
    CAS2 OR CAS3?
    Oct 2015
    Cas3 I think.
    I had those problems with E90, E60 and Mini R52
    keturi's Avatar
    Oct 2010
    Lievatu
    Common problem with that cars usually is not ELV. What fault codes you got in cas and dsc? If you are sure is ELV, the can swap electric part of ELW from E90 to Mini and back. They just from outside are different, inside the same, just got 2 types of ELV, 3 pins or 4 pins plug.
    Oct 2015
    I ask because I dont know where is the problem and how to fix it.
    We all know the red steering lock light in the dash on those cars. Solutions like reset cas counter and emulator are not valid for me, so I want to know where is the problem and how to fix.
    Oct 2015
    Any help for this problem?
    keturi's Avatar
    Oct 2010
    Lievatu
    Quote Originally Posted by Perryking View Post
    So I want to know WHAT THE FAULT CODES GOT CAS AND DSC as I wrote in the comment before.
    P.S. Proper question is 50% of answer mate
