Results 1 to 4 of 4
    AndriyM6's Avatar
    Nov 2012
    Default 2016 Chevrolet Equinox speedo replacement
    Hello. Can somebody help me identify where mileage stored on this board. I see One processor and eprom looking microchip.
    Thank you.
    Sent from my SM-N960U using Tapatalk
    letalcrudo's Avatar
    Nov 2015
    Canada
    AndriyM6's Avatar
    Nov 2012
    It's a flooded car. BCM replaced with new one and when program BCM says they cannot load a odometer because instrument cluster not working. I don't have original bcm only cluster. I'm looking to buy used cluster and transfer mileage.
    Quote Originally Posted by letalcrudo View Post
    ascrap2003's Avatar
    Sep 2016
    Texas
    Wont matter because on most newer GM have mileage in BCM or BCM/Cluster and if mileage on cluster is higher than wont count up, and if lower on cluster will jump to bcm mileage,
    Program BCM with mileage first, then set cluster to same or lower mileage and make sure both BCM and Cluster VIN Match. Also have to consider some newer models will need extended programming that most of us can't do yet.
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
