Results 1 to 5 of 5
    Feb 2011
    Default BMW E61 - Airbag 93F9 Internal Fault - clear please
    I've this BMW E61 / yr 2005 with a permanent DTC 93F9 Internal Fault on SGM module.
    SGM module is: 65.77-6962703 HW:14
    SGM High 21
    I've read Motorola inside 9S12 with mask 0L94R
    Can someone please check and correct attached file.
    Thank you so much in advance.
    BR,
    PM.
    Oct 2016
    if you have icom with expert mode or Autel can you fix it
    Feb 2011
    Quote Originally Posted by bujarmiftari View Post
    Thanks. Tried with Autel. Didn't worked...
    Any more ideas?
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Check this and report ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  5. The Following User Says Thank You to dragon100 For This Useful Post:
    psam (2nd June, 2019)
    Feb 2011
    Sorry for not giving results before. I completelly forgot...
    Anyway here it goes...
    That one didn't worked with software. I managed to solve the problem replacing the unit.
    In fact I think that mostlly this problem it hardware related and refelects in software.
    Recentelly, I had another case (same error), and solved it (at least so far...) by replacing those big capacitor inside the unit.
    BR,
    PM.
    Quote Originally Posted by dragon100 View Post
